fs2004 INSTALLING QUSTION
Old December 20th 03, 03:45 PM
Tlewis95
Default fs2004 INSTALLING QUSTION
I HAVE BEEN USEING FS FOR YEARS.
FS2004 i have had since the day it was released.
A few days ago, everytime I hit the display menu under settings, It would just
close no messages or anything. I tried to re-install FS and it fixed the
problem. However when I went back to launch FS agian the same day, the same
problem came back! Any suggestions?
THANK YOU IN ADVANCE!
TL age 13
P.S Happy 100th anniversary of flight!
Old December 26th 03, 10:59 AM
Siberian Goose
Hi There,
I had the same problem with FS2002.
Try the following as this cured the problem for me.
First of all try removing some program icons from the task bar & start menu
if there is some as these will be running & consuming system memory.
Secondly, go to start Run & type in DXDIAG to run a directx diagnostic
test.
I did both of these & the problem was solved. I am not saying that this will
cure it for you but it is worth trying.
Phil.
"Tlewis95" wrote in message
just
same
TL age 13
Disappointed with FS2004 Phiber Optik Simulators 5 October 12th 03 05:13 PM
Abacus and FS2004 compat question George Lewis Simulators 2 October 3rd 03 03:22 AM
Bridges in FS2004 Kevin Reilly Simulators 18 October 3rd 03 12:00 AM
Help needed - fs2004 zaps fs2002 props Ian D Simulators 1 September 11th 03 11:20 PM
FS2004 Pauses When Real World Weather Won't Download Andrew Watson Simulators 1 September 8th 03 10:08 AM
