![]() "Martin Gregorie" wrote... Has anybody used SoaringPilot on a Palm m100? If so: - what are its pros and cons? - how does the m100 display readability compare with an IPAQ 3630 or 3850 in the cockpit? I've run SoaringPilot on an m100, and have also run homebrew software on an m100 and an iPAQ 3950. The m100 doesn't quite have enough processing power to drive a moving map, so I primarily used it for textual displays (final glide, etc.). The m100 display has far more contrast than the iPAQ or other color PDAs. It is quite readable in the cockpit under almost any lighting condition, except near sunset. The iPAQ screen is great indoors, but marginal in the cockpit. Under direct sun, there isn't enough contrast for my nearing 50 year-old eyes, plus glare becomes a problem at certain sun angles (a good screen protector helps). It's difficult to distinguish colors, and I'm constantly fiddling with the colors I use to improve the readability. The 3630 and 3850 do have the older reflective displays, which are a bit more readable in direct sunlight. Marc |
On Sat, 06 Sep 2003 17:02:23 GMT, "Marc Ramsey"
wrote: "Martin Gregorie" wrote... Has anybody used SoaringPilot on a Palm m100? If so: - what are its pros and cons? - how does the m100 display readability compare with an IPAQ 3630 or 3850 in the cockpit? I've run SoaringPilot on an m100, and have also run homebrew software on an m100 and an iPAQ 3950. The m100 doesn't quite have enough processing power to drive a moving map, so I primarily used it for textual displays (final glide, etc.). The m100 display has far more contrast than the iPAQ or other color PDAs. It is quite readable in the cockpit under almost any lighting condition, except near sunset. The iPAQ screen is great indoors, but marginal in the cockpit. Under direct sun, there isn't enough contrast for my nearing 50 year-old eyes, plus glare becomes a problem at certain sun angles (a good screen protector helps). It's difficult to distinguish colors, and I'm constantly fiddling with the colors I use to improve the readability. The 3630 and 3850 do have the older reflective displays, which are a bit more readable in direct sunlight. Thanks for the analysis. FWIW if I go the IPAQ way I'll run XCSoar, which has an uncluttered, essentially black & white display which would presumably sort out some of the contrast problems. It seems that all the PDAs I know about have problems: - no external power connection for the Palm m100 and slow - Compaq Aero 1500 displays fade out in a sunlit cockpit as they get hot - IPAQ 3630 and 3850 get hot and crash in a sunlit cockpit. Are there any other WinCE PDAs I should be looking at? I'm primarily interested in using a PDA system to display a moving map for general navigation and restricted airspace avoidance. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
It seems that all the PDAs I know about have problems: - no external power connection for the Palm m100 and slow You can live without external power, I used NiMH rechargeables, and could easily get 7 or 8 flying hours per charge. It is slow, though... - Compaq Aero 1500 displays fade out in a sunlit cockpit as they get hot True, but keep a white cloth or hat over it until takeoff, and it will be fine. - IPAQ 3630 and 3850 get hot and crash in a sunlit cockpit. My 3950 has never crashed due to heat, even when the temperature exceeds 40C on the ramp. The screen is also unaffected. Are there any other WinCE PDAs I should be looking at? The Axim is inexpensive, but finding an appropriate mount may still be a problem. I'm primarily interested in using a PDA system to display a moving map for general navigation and restricted airspace avoidance. The upcoming replacement for the low-end Palm Zire interests me. It allegedly has a decently fast ARM processor running PalmOS 5, 8 mb of memory (instead of 2), an external power jack, and a high contrast monochrome screen like the m100. The main problem is likely to be finding a way to get GPS data into the thing... Marc |
I use SoaringPilot on a M105 since 2 years, and I am very happy with
it. If you keep the number of SUA data at minimum, the moving map is very usable (about 2/3 s refresh time with Afterburner at 24MHz). With cheap disposable batteries, I get about 10 flight hours: more than sufficient -even for me!- for a 500km task. For the battery change problem, I have a good solution: get a 3v button size battery, 2 thin copper blades attached to each side with insulating tape and inserted behind the battery contacts while changing the batteries! I use SP with a small mouse-shaped Deluo GPS, wich is very convenient. Have a good flight! |
AVIATIONTOOLBOX: moving map script (was PocketEfis & PalmEfis) | Darrel Toepfer | General Aviation | 0 | August 11th 04 01:34 PM |
Navzilla Moving Map Software for iPAQs and Laptops | Navzilla Team | Piloting | 1 | May 22nd 04 10:10 PM |
Navzilla Moving Map Software for iPAQs and Laptops | Navzilla Team | Aviation Marketplace | 0 | May 20th 04 03:01 AM |
Moving Map on IPAQ | Bob | Simulators | 0 | March 25th 04 09:30 PM |
Engine moving day... | Gene Z. Ragan | Home Built | 2 | March 16th 04 01:26 AM |
