Question of the Day
Old September 10th 03, 12:41 AM
Jim Vincent
Since mass is a constant factor on both sides of the equation, it
cancels out.
You need to compare one equation to the other. The masses are different. Yes,
for one glider, the masses cancel out, but not when comparing two different
masses, cetarus parabus.
Jim Vincent
CFIG
N483SZ
Old September 10th 03, 12:59 AM
mm
"Jim Vincent" wrote in message
It will gain more height with ballast. The
kinetic energy is defined as 1/2*m*v squared.
The potential energy is m*g*h,
So for example, if a gldier weighs twice as much, it will
gain twice the height, or at least I think so!
Again, take out the constants. Both aircraft have the same velocity at
beginning, 100Kts. Assume, for the sake of argument, that they have the
same
velocity at the end, say 30 kts (I know the heavier one will stall first,
but
in a vertical pull up, the wing loading is zero, so the stall speed would
be
very close).
SO at the beginning, the delta in kinetic energy for two ships travelling
same speed is only proportional to the mass. Since the heavier one weighs
more,
it has more kinetic energy. At the end of the pull up, when all the
kinetic
is converted to potential, take out the constants again (g), and the only
remaining variable is h. h is proportionally more for the heavier ship.
And,
as I said before, this is not accounting for drag.
P.S. I f'in hate calcusus. R dR d theta double dot!
Jim Vincent
CFIG
N483SZ
Wrong again. If you can't do the math right, at least stop doing it in
public.
"The only remaining variable is" not h, it is mh. mh is "proportionally
more for the heavier ship"; h is the same.
Old September 10th 03, 01:28 AM
mm
cancels out.
Yes,
different
Jim Vincent
CFIG
N483SZ
You don't know what you are talking about.
Old September 10th 03, 02:25 AM
Jim Vincent
Yo mamma.
Jim Vincent
CFIG
N483SZ
Old September 10th 03, 02:27 AM
Jim Vincent
public.
Yo' daddy
Jim Vincent
CFIG
N483SZ
Old September 10th 03, 02:46 AM
Jim Vincent
Yeah, I was wrong, the mass does cancel out.
My mommy and daddy.
Jim Vincent
CFIG
N483SZ
Old September 10th 03, 08:30 AM
Christian Husvik
cancels out.
You are confused. Can you explain what you mean by comparing one
equation to the other?
Let me try:
For glider one we have:
1/2*m1*v1^2=m1*g*h1
For glider two:
1/2*m2*v2^2=m2*g*h1
since the equations are quite similar for both gliders, of course ;-)
So comparing the two equations, you can now see that the mass,
surprisingly enough for you ;-, cancels out for both gliders.
I do hope you are not "helping" your kids doing their math-homework!
Christian 8-)
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 10:40 PM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
Special Flight Setup Question (COF) Dudley Henriques Simulators 4 October 11th 03 01:14 AM
T Tail question Paul Austin Military Aviation 7 September 23rd 03 07:05 PM
