Jim Kelly wrote:
Has anyone thought to try (very) reflective tape, Of course. Our club has equipped all gliders with chrome tape. The opinions vary from "it doesn't hurt" to "we will be able to claim that we tried everything". Stefan |
Jim Kelly wrote:
Has anyone thought to try (very) reflective tape, Yes. Reflective tape, and if you repaint a glider, paint the wingtips white or reflective. It seems I've seen quite a few with dark wingtips. Sure makes it easy to hit one's head... I also wrap my portable ELT in reflective tape. Saves having a separate mirror... |
Mark James Boyd wrote:
Jim Kelly wrote: I also wrap my portable ELT in reflective tape. Saves having a separate mirror... Have you tried to use it? A real signalling mirror is flat, reflective on both sides, and has a small hole in the center so you can aim it. One you can't aim might be worthless. -- ----- Replace "SPAM" with "charter" to email me directly Eric Greenwell Washington State USA |
Eric Greenwell wrote: Mark James Boyd wrote: Jim Kelly wrote: I also wrap my portable ELT in reflective tape. Saves having a separate mirror... Have you tried to use it? A real signalling mirror is flat, reflective on both sides, and has a small hole in the center so you can aim it. One you can't aim might be worthless. -- This tape actually has a checker pattern and reflects in all directions. I'd bet the signal mirror would work better, but might depend on my skill using it ;-[ |
SNIP
A flat signal mirror has a narrow and therefor much brighter beam. I'd bet the signal mirror would work better, but might depend on my skill using it ;-[ They are very easy to aim, because they are reflective on _both_ sides and have a hole in the center. You are actually aiming it (using the hole and the reflective back side), not just waving it in the general direction of the aircraft or whatever you are trying to signal. -- ----- Replace 'SPAM' with 'charter' to email me directly Eric Greenwell Washington State USA Eric, Not ever having seen one, I can't quite get my mind around how a hole in the centre helps you aim it. If the sun is 45 degrees left and you aim at the target aircraft, won't the reflected beam be 45 degrees right of the target? I'm not arguing - I'm sure they work, I'd just like a simple explanation of how! Rob |
On 5 Dec 2003 16:38:12 GMT, Robert John
wrote: .... text removed... Not ever having seen one, I can't quite get my mind around how a hole in the centre helps you aim it. If the sun is 45 degrees left and you aim at the target aircraft, won't the reflected beam be 45 degrees right of the target? I'm not arguing - I'm sure they work, I'd just like a simple explanation of how! This may not be simple, but most of the real signal mirrors I am familar with have a hole in the backside that is surrounded with a circle of retroreflective material (like 3M Scotchlite), typically red in color. The sunlight is reflected off the mirror surface normally. Where the sunlight hits the Scotchlite, it is retroreflected directly only the incoming path. A small portion (about 4%) of this reflected sunlight, now colored red by the Scotchlite, is in turn reflected backwards again by the front surface of the mirror (toward the user looking through the backside of the mirror). The usual optics rules for mirrors (angle of incidence equals angle of reflection) means that this retroreflected (red) radiation appears to come along the exact angle as the outgoing reflected sun light. The bottom line is that when you look outward through the small hole in the backside of the mirror, all you have to do is put the small red spot you see on the target you are trying to signal. The Scotchlite properties and the rules of optics reflection assure that the red spot and the reflected sunlight are pointing in the exact same direction. Sorry UseNet does not permit embedded graphics. Bob |
Robert John wrote in message ...
SNIP A flat signal mirror has a narrow and therefor much brighter beam. I'd bet the signal mirror would work better, but might depend on my skill using it ;-[ They are very easy to aim, because they are reflective on _both_ sides and have a hole in the center. You are actually aiming it (using the hole and the reflective back side), not just waving it in the general direction of the aircraft or whatever you are trying to signal. -- ----- Replace 'SPAM' with 'charter' to email me directly Eric Greenwell Washington State USA Eric, Not ever having seen one, I can't quite get my mind around how a hole in the centre helps you aim it. If the sun is 45 degrees left and you aim at the target aircraft, won't the reflected beam be 45 degrees right of the target? I'm not arguing - I'm sure they work, I'd just like a simple explanation of how! Rob You can also buy little stick on convex mirrors for $2.00 or less each at auto parts stores. Wouldn't the reflected light go out in a cone shape? After a few hundred feet the cone pattern could be quite large. |
"Slingsby" wrote in message om... Robert John wrote in message ... SNIP A flat signal mirror has a narrow and therefor much brighter beam. You can also buy little stick on convex mirrors for $2.00 or less each at auto parts stores. Wouldn't the reflected light go out in a cone shape? After a few hundred feet the cone pattern could be quite large. ...and therefore (by the law of inverse squares) not nearly as bright. Vaughn |
| Cherokee Strobe Noise | Jonathan Goodish | Owning | 20 | November 2nd 04 03:42 AM |
| Strobe light usage | Roger Long | Piloting | 4 | August 7th 04 05:21 PM |
| Anti collision light mod for Piper Arrow 1968 model? | Frode Berg | Owning | 4 | May 20th 04 06:16 AM |
