Strobe light usage
Old August 5th 04, 02:38 PM
Roger Long
Default Strobe light usage
"Peter Duniho"
As for using the strobes as a way to communicate to the tower, that only
works if there's an official policy regarding that. There's not, so it
really doesn't matter what you're trying to do, there's no way for you to
use the strobes to communicate to the tower that you believe you are
cleared
onto an active runway.
I agree that lack of uniformity on this diminishes it's usefulness. However,
that's the case with a number of gray area issues. If it's the right thing
to do, we should do it to promote it.
When the tower sees your strobes come on just as your runway clearance is
coming through their headphones, it's got to help confirm that you are the
plane they are talking to and not another one that thinks they are where you
are and about to enter from an intersection. It's happened more than once.
For what it's worth, some airplanes have ONLY strobes and no beacon. The
strobes are the required "anticollision" light, and as such are required
to
be on any time the airplane is moving, including taxiing.
In that case, I agree, their strobes would have to be on. Better would be
for them to get a beacon.
Besides all the above, I've heard several places that the strobes when
cleared is the procedure the airlines use an my observations seem to confirm
this. I like looking professional to the tower and doing it like the
airlines seems a good guide.
Roger Long
Old August 6th 04, 09:20 AM
Roger Halstead
On Fri, 6 Aug 2004 00:27:46 +0100, "Paul Sengupta"
"gatt" wrote in message
Most of the people I've rented from discourage it altogether unless in
IFR,
which means I've annoyed many of them 'cause if there's a lot of traffic
or
poor VFR I do it anyway. :
You're supposed to turn your strobes off in the clouds as the
reflection can be blindingly bright.
I'd take the "blindingly bringht any day over the vertigo they are
likely to cause. :-))
www.rogerhalstead.com
Paul
Old August 6th 04, 09:24 AM
Roger Halstead
On Fri, 06 Aug 2004 00:01:20 GMT, David Megginson
Actually, I think that the reason was the people mistakenly believed that
the strobes reflecting off the clouds could cause vertigo or seizures.
That's recently been debunked (unless you're epileptic, of course), but I do
not remember the source offhand.
That may have been debunked but I can point to a number of local
pilots, including me, who have found the strobes to be a bit more than
unsetteling in some clouds. It has noting to do with epilictcy
either. It's not the flashing rate, it's the stroboscopic effect like
you see in some night clubs. It makes you dizzy just trying to walk.
It there is texture to the clouds the strobes can easily create an
effect much like the "leans" you get from the same kind of clouds in
the day.
Day or night, the reflection of my strobes in cloud has never been a problem
-- it's not even enough to affect my night vision.
All the best,
David
Old August 6th 04, 04:01 PM
Rick Durden
Roger,
I'm trying to find the regulation you reference. 91.209 requires
operation of position lights at night but not anticollision lights.
91.209(b) calls for operation of anticollision lights unless the PIC
"determines that, because of operating conditions, it would be in the
interest of safety to turn the lights off."
I may have missed a reg that requires operation of anti-collision
lights, but I've missed stuff before and will again.
A number of aircraft POH's and placards state that the strobes should
not be operated on the ground, in fog or in cloud. Because of the
potential to destroy the night vision of others who may be in the area
(a safety issue), I have always taught that strobes should be turned
on on taking the runway and off on exiting the runway. While it is a
personal preference on the part of the pilot, I've felt that safety
dictates that they be left off when on the ground (even if the a/c has
no beacon) due to the potential for danger to others. (Or distraction
as others comment on the guy who taxies with his strobes on during the
day and promptly walk into the open manhole in the ramp g.)
All the best,
Rick
Roger Halstead wrote in message . ..
On 04 Aug 2004 19:58:46 -0700, Javier Henderson
"Roger Long" writes:
Have I been wrong all this time and is this booklet authoritative enough
that I should change my procedures?
Strobes on the ground, unless you're taxiing onto the active for
takeoff, or just landed, are very annoying. Rather than having to keep
track of yet one more thing, I prefer to simplify my workload by
leaving them off on the ground until the tower clears me to taxi onto
I can't do that. Regulations require they be on as soon as I start the
engine. (any time the prop is turning)
the active runway. Upon landing, I turn the strobes off after exiting
the runway, along with everything else on the post-landing checklist.
My HO, your mileage may vary, etc.
-jav
Old August 7th 04, 05:21 PM
Ron Natalie
"Rick Durden" wrote in message
(a safety issue),
It's also a nice courtesy to kill the landing light when it might affect the night vision
of others (sort of like dimming your high beams).
Skycraft Landing Light Question Jay Honeck Owning 15 February 3rd 05 07:49 PM
C-172 landing light switch JFLEISC Piloting 16 May 6th 04 02:15 AM
C-172 landing light switch JFLEISC Owning 10 May 6th 04 12:05 AM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 01:07 PM
OT but very funny after some of the posts we have had of late. Mycroft Military Aviation 1 August 8th 03 11:09 PM
