High tow vs. low tow for rough tows (long)
Old December 5th 03, 06:53 PM
Mark James Boyd
A lot of different techniques - little consensus
Bruce - Hi to slow and get slack out, then match speeds by diving
Brian - Yaw to reduce snappiness when line comes taut
Janusz - Shorter rope so tug and glider are in the same air
Michel - Low tow and avoid slack line
Although Bruce's approach is most elegant, I think it
also requires the most skill and best timing. Matching
airspeeds is challenging.
Brian's approach is pretty standard, but also requires a
little bit of timing. I'd also be surprised if he
isn't subtly using a little bit of dive at the end
to help match airspeeds.
Janusz and his 20 meter rope leaves me speechless.
I'd have to try it to have any real opinion.
Michel's low tow seems like a low-skill winner.
As long as you don't get too low and scare the towpilot
into releasing it seems you'll do ok.
Not mentioned is the use of spoilers. I've noticed
one ranked pilot who flies a slick glider sometimes with
ballast uses slight spoiler adjustment to regulate slack line.
Any rotor towpilots have any further opinions?
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 08:28 PM
(PIREP, long) Cherokee 180 from Bay Area to Bishop, CA Dave Jacobowitz Piloting 15 June 24th 04 01:11 AM
Flight test update - long nauga Home Built 1 June 5th 04 04:09 AM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 04:02 PM
MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS MT. DIABLO HIGH SCHOOL PHOTOS Home Built 1 October 13th 03 04:35 AM
Copyright Š2004-2025 AviationBanter.
