Mini Coupe
Old October 4th 04, 03:29 AM
Rich S.
"Morgans" wrote in message
Some instances I have heard of do keep a "radiator", but it usually is a
water to water heat exchanger. Seems it was a big commercial rig. It has
the advantage of not having salt water running through the engine.
Disadvantages are more complexity, and more to fail. You have to have a
pump to move that seawater to the exchanger, too.
My 19' skiboat had FWC (Fresh Water Cooling) using a heat exchanger. They
are fairly common on the coasts where salt water operation is a fact of
life. If it's in an inboard/outboard installation, the outboard unit has the
pump. If it's strictly inboard, there'll be an extra pump driven off the
accessory belt, the back of the alternator or some other rotating accessory.
The normal engine water pump circulates the engine coolant.
Rich S.
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 09:36 PM
Mini Fly-In Drachten (EHDR) 5-6-7 juni Zier en van de Steenoven Home Built 0 May 28th 04 01:14 AM
Mini Imp Randall Robertson Home Built 0 November 25th 03 12:17 AM
mini copter strikes again tim Home Built 4 November 21st 03 12:47 AM
