#28
"Greg Arnold" wrote in message news:y25Gb.21786$J77.6384@fed1read07... Would gliders avoid the problem if they used the 4th and 5th generation gel coat formulations? If so, why have the glider companies chosen to use an older technology? The answer is probably no. The adhesive nature of the bond would still be inferior to the cohesive bond of an all polyester or vinylester system. The reason for not making the change is that the current products used conform with the type certificate and they are known quantitys with acceptable service lives (in the factorys eyes). Making a change introduces many unknowns, at least in the minds of the designers. This is a case of accepting the current state of affairs with the perception that changes might be more painful than living with todays reality..... Scott. |
| Thread Tools | |
| Display Modes | |
| Commercial Glider refinishing book | Martin Carolan | Soaring | 0 | December 15th 03 10:41 AM |
| REFINISHING | Ventus B | Soaring | 32 | December 3rd 03 11:14 PM |
| Older glass glider refinishing question | Gus Rasch | Soaring | 6 | November 10th 03 01:18 AM |
| Refinishing Your Aircraft (now in Oregon) | aerocomposites | Home Built | 0 | September 24th 03 06:29 AM |
| Tracon II Shortcut key for "THEN" | Jack Frost | Simulators | 0 | August 17th 03 03:54 PM |
