Yes I agree. Another example is big cities versus small ones.
I almost never find thermals over the larger areas of housings and buildings belonging to a somewhat larger urban area. Just to many trigger points producing small and low thermals only. However when over a village or a group of farm housings it is usually very easy to find the spot where good thermals are triggered off using the heated air of the direct environment. Karel, NL "Bill Daniels" schreef in bericht hlink.net... "Andy Durbin" wrote in message om... "Roger Worden" wrote in message om... In the Jan. 2004 issue of Model Aviation, in the Radio Control Soaring column, Real Smart Guy candidate Mike Garton proposes a "condensation analogy" to suggest places to look for thermals to trigger. Imagine water condensing on a ceiling: it drips first from the low spots or tiny bumps. Now imagine heated, but relatively stable, air along the ground. If it's "trying" to rise, might it not "drip up" first from the higher spots, little hills, even trees? If it's moving slowly horizontally, and encounters a tree line, it might be forced up enough to trigger a thermal. His experience with models supports the theory on the small scale. Does y'all's experience support it at the larger scale? Roger Worden Yes it seems to work that way. A moving object may also disturb motionless hot air and start a thermal. I was once low over a local dirt strip, I think turning base to land, when a truck drove into a large flat dirt area. It triggered a good thermal that got me up and home. Andy (GY) One thing to keep in mind is that there is a ratio between thermal triggers and the heated air available to be triggered. In other words, in weak conditions over rugged terrain, there is a surplus of available triggers, but a deficit of heater air to be triggered. Sometimes there will be no thermal over an obvious trigger site because the available bouyant air was already triggered by a lesser, but adequate trigger upwind. In these cases, potential trigger sites are not a reliable thermal indicator. In strong conditions, over mostly uniform, flat surfaces, the few available trigger sites become more important. Bill Daniels |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Dover short pilots since vaccine order | Roman Bystrianyk | Naval Aviation | 0 | December 29th 04 01:47 AM |
| [OT] USA - TSA Obstructing Armed Pilots? | No Spam! | Military Aviation | 120 | January 27th 04 11:19 AM |
| [OT] USA - TSA Obstructing Armed Pilots? | No Spam! | General Aviation | 3 | December 23rd 03 09:53 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
