If you have a true vacuum bottle as a flask you should not need more
insulation but if you are using a winter capacity you can use anything to put airspace between the vario and the glare shield the white beaded foam is probably best but a pain and messy to work with there are some flexible foam rubbers you could use. There are other reasons to insulate your capacity and use the copper wool inside, maybe we can hear from Mike Borgelt he can describe the reasons more better er er than I. Pete "Chris Nicholas" wrote in message ... All the installations I have seen use a standard vacuum flask with no additional insulation, but they were all buried either beneath/behind the instrument panel, or inside the fuselage - anyway in shadow. A key element I have read about, and all mine have been fitted with, is copper pan scourers loosely filling the interior of the flask, so that temperature variation within the capacity is elinimated. However, I am no expert, and I look forward to some who are telling how it really should be done. Chris N. |
| Thread Tools | |
| Display Modes | |
| Tasman audio vario for sale | JJ Sinclair | Soaring | 8 | February 1st 14 03:01 PM |
| Ball vario overhaul? | Anthony Turiano | Soaring | 6 | June 17th 09 09:06 PM |
| Firewall Insulation | Marv Hamm | Home Built | 2 | August 31st 04 03:14 AM |
| Firewall Insulation | Kyle Boatright | Home Built | 1 | August 27th 04 02:11 AM |
| radio / vario interference - HELP! | Chris Davison | Soaring | 13 | November 3rd 03 07:09 AM |
