The NACA 5-digit airfoils are set up in a similar manner
to the 4-digit airfoils. The primary difference is the use of a different camber line. In a 5-digit airfoil, 1.5 times the first digit is the design lift coefficient in tenths, the second and third digits are one-half the distance from the leading edge to the location of maximum camber in percent of the chord, and the fourth and fifth digits are the thickness in percent of the chord. For example, a NACA 23015 airfoil has a design lift coefficient of 0.3, has the maximum camber at 0.15c, and is 15% thick. Additionally, the first three digits indicate the mean line used. In this case, the mean line designation is 230. The 5-digit airfoils use the same thickness distribution as the 4-digit airfoils. This example is displayed below. NACA 23015 NACA 230 mean line (230) 15 thickness, % (15%) NACA 2 (design lift coefficient * 10) / 1.5, (0.3) 30 2 * (position, maximum camber), (0.30 / 2 = 0.15c) 15 NACA 23 0 type of camber line used 15 "c hinds" wrote in message om... How are they decoded? The aircraft I am constructing has the NACA Airfoil number of 65(3)518-A7. Any comments or suggestions are welcome. Thanks, Clark |
| Thread Tools | |
| Display Modes | |
| Press fit numbers? | Boelkowj | Home Built | 1 | April 29th 04 07:51 PM |
| Any Canadians Who Can Provide Numbers on a Champ, Taylorcraft, or Luscombe with Warp Drive Propeller? | Larry Smith | Home Built | 7 | December 21st 03 10:39 PM |
| Reverse NACA duct | Chris W | Home Built | 22 | October 28th 03 11:59 PM |
| NACA duct ventrui | Chris W | Home Built | 7 | October 27th 03 05:11 PM |
| Darpa contract numbers | - = krusty = - | Home Built | 9 | July 23rd 03 04:22 AM |
