Best airfoil?
Old January 26th 04, 06:19 AM
Eric Greenwell
Scott wrote:
If one were to design their own sailplane, which airfoil would be a good
choice for low drag and fairly low speed (ie, an ultralight part 103
sailplane for exampl)? In other words, is a thicker airfoil (more lift)
better at slow speeds or a thinner airfoil (less drag)? Which type would
give the best glide ratio with all other things being equal?
Have you read Fundamentals of Sailplane Design? That'd be a good place
to start if you haven't. Join the Sailplane Homebuilder's Associaton at
the same time (buy the book from them, too).
Thicker and thinner don't mean much; instead, you need to be talking
about the characteristics you want, such stall speeds, desired L/D at
max and cruise speeds, wing loadings, construction (wood and fabric,
carbon, or ?) and so on. Theennn you can start asking about the airfoil!
change "netto" to "net" to email me directly
Eric Greenwell
Washington State
USA
Glasair 1 TD Airfoil ELIPPSE Home Built 3 January 19th 05 06:15 PM
S-18 airfoil JDKAHN Home Built 0 October 30th 04 05:35 AM
sa 500 starlet airfoil sal Home Built 0 October 5th 04 11:21 AM
Airfoil aerodynamic simulator... Thomas J. Paladino Jr. Piloting 4 May 17th 04 03:41 PM
Curve fitting to airfoil coordinates Larry Goddard Soaring 13 January 21st 04 05:21 PM
