#11
At 05:30 11 February 2004, Tango4 wrote:
Snip .... But why not try doing it the real way? 300km - Straight out You can only claim gold distance out of a straight 300k, diamond goal is a triangle or O/R. 500 km - O/R or at least a full FAI triangle with home as one apex. That would be nice, unfortunately at some clubs (including mine) you fall off the edge of the country or hit airspace if you try to fly a 500k triangle, let alone an O/R, a 500k triangle with the club halfway along one leg might just be on, except either the sea breeze would get you, or you'd spend way too long jumping wave gaps. snip... |
I can fit a 750km FAI triangle into the Uk and from Parham it's actually
acheivable. PAR, PRE, BRN, PAR ( Parham Prestign up through the Midlands/manchester airspace gap to Burn and then home to Parham ( via approximately Newbury to miss the Heathrow airspace ) The FAI distance is 755km tha actual distance around the airspaces is about 785. Not impossible if we get another day like August 15th last year. Ian |
acheivable. PAR, PRE, BRN, PAR ( Parham Prestign up through the Midlands/manchester airspace gap to Burn and then home to Parham ( via approximately Newbury to miss the Heathrow airspace ) The FAI distance is 755km tha actual distance around the airspaces is about 785. Not impossible if we get another day like August 15th last year. Ian Have you ever been through Manchesters low level corridor? it's busy! or did you mean something else? Rgds, Derrick. |
Mark Grubb wrote:
Trying to find the following information and an FAI Sporting Code reference for the following: 1) The minimum separation between turnpoints on a 3-turn task 10 km 2) Maximum distance between start and finish on a closed circuit FAI task (O&R or Triangle) 0 km (closed circuit implies start point = finish point) -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
| Thread Tools | |
| Display Modes | |
| GPT (Gulfport MS) ILS 14 question | A Lieberman | Instrument Flight Rules | 18 | January 30th 05 05:51 PM |
| VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 06:03 AM |
| Legal question - Pilot liability and possible involvement with a crime | John | Piloting | 5 | November 20th 03 10:40 PM |
| Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 02:26 AM |
| Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 01:14 AM |
