1-34 Rudder
Old February 14th 04, 04:41 PM
Roy Bourgeois
Doug:
Actually - your observation is quite perceptive. The 1-34 IS a bit
under-ruddered. However, the problem is not it's size but rather the
fuselage length and the distance of the rudder from the center of the yaw
axis. The 1-34 original design concept was to be a "metalized" Slingsby
Dart - with optional 15 or 17m wings. Schweizer only made 1 set of 17
meter wings (nobody wanted them) but they made the fuselage much longer
than necessary for a 15m ship. Compare the fuselage length between the
1-34 and the 1-35 - both are 15m gliders but there is something like a 40"
difference between center of yaw axis and the rudder hinge line. So - you
would have to make the rudder much, much, bigger on the 1-34 to have a
significant effect (and that creates a weight and balance problem because
the weight is so far back).
This is why the big open class gliders like the Nimbus 3 have spoilers on
the wing tips to help the rudder. Because of the fuselage length needed
for the long wings - you can't make a rudder big enough.
Roy B.
Air Bus 300 crash in NY now blamed on co-pilot's improper use of rudder Corky Scott Piloting 30 October 28th 04 05:10 AM
B2 Split Rudder Emilio Military Aviation 8 April 12th 04 11:43 AM
P-51 Rudder Aerodynamics Hawkeye Hughes Home Built 1 March 15th 04 10:24 AM
A lesson learned - Invisible rider with foot on right rudder Dave Butler Piloting 2 October 16th 03 10:58 PM
Cessna 150 Price Outlook Charles Talleyrand Owning 80 October 16th 03 03:18 PM
