How to drill a cenetered hole in end of solid rod
Old October 16th 04, 04:43 PM
Jerry J. Wass
You need a centering head square---http://www.wttool.com/p/1279-0006-----
put end of rod in Vee, scribe line using center blade, --rotate 90deg, scribe
again, intersection of scribed lines is center of circle...QED
Kyle Boatright wrote:
Got a lathe? Failing that, you could lay the thing out by hand, carefully
centerpunch it, then put it in a drill press. I'm sure you already know
this, but with care, you'd be amazed at how precise you can be on *one*
small part. Especially if it is the second or third one you've attempted to
make. ;-)
KB
"Scott" wrote in message
I need to make a specialized tool and am looking for a way to drill a 1/16"
hole EXACTLY in the center of the end of a piece of say 1/2" of 3/4" solid
aluminum rod. In other words, I am trying to make something similar to a
screwdriver using solid aluminum rod for the handle and 1/16" brass rod as
the blade.
Scott
http://corbenflyer.tripod.com/
Building RV-4
Gotta Fly or Gonna Die
Fairing question... Tina Marie Home Built 5 July 16th 03 12:18 AM
