IPAQ Wiring - which pins are used
Old February 23rd 04, 12:02 AM
Gary
Here goes
1 Power V_ADP + 5 Volt
2 Power V_ADP +
3 Power V_ADP +
4 Power V_ADP +
5 Reserved - Do not use
6 RS232 DCD
7 RS232 RXD For GPS
8 RS232 TXD For GPS
9 RS232 DTR
10 GND Ground Negative side for your 5 volt -
11 RS232 DSR
12 RS232 RTS
13 RS232 CTS
14 DS232 RING
15 GND Ground
16 No Connect - Do Not Use
17 USB Detect
18 No Connect - Do Not Use
19 USB - UDC +
20 No Connect - Do Not Use
21 USB - UDC -
22 Ground
Note: Pin out- 22 Pin Cradle Connector IPAQ Side
Notched Side will be the even numbers
Gary
(Michael) wrote in message . com...
There are commercial solutions availabe, ready to use.
But I would like to know which pins are used on the
IPAQ 3900 side for a two wire communication with the GPS
and which pins are used for the +5V power supply.
The IPAQ connector has some 22 pins and I guess that for
power pins 19 gets +5V and pin 21 gets ground.
A standard serial cable may connect pins 6,7,8,9,10,11,12,13,14,
whereas the USB cable connects to what? Is it pin 17 and 22 or
some of the serial pins?
Can someone explain the pin usage for a 4 wire power/com cable
on the IPAq side?
Thanks a lot
Michael
iPaq wiring, cradles and mounts for gliders - Ideas?? Jim Kelly Soaring 12 December 5th 03 12:45 AM
Commercial - iPAQ Cradles In Stock Paul Remde Soaring 0 October 29th 03 11:57 PM
Ipaq - GPS_Log Help needed (Long) Steve B Soaring 1 September 27th 03 07:00 AM
iPAQ h2210/h2215 Review Paul Remde Soaring 0 September 3rd 03 04:45 AM
iPaq screen viewability Raphael Warshaw Soaring 7 July 27th 03 07:02 PM
