Scott wrote ...
I need to make a specialized tool and am looking for a way to drill a 1/16" hole EXACTLY in the center of the end of a piece of say 1/2" of 3/4" solid aluminum rod. ... Can't be done. Not "EXACTLY" anyway. If somebody hands you one that's "exactly" dead nuts center, they simply aren't using a fine enough means of measuring. So pick your tolerance, .005", .001", ..0005", .0001", a nanometer, an angstrom, a yoctometer, whatever. If something within a few thousandths is sufficiently accurate, a drill press alone will do the job. Trick is to make a one-time custom fit vise in situ. Take two chunks of similar dimension hardwood, say 1x2 oak. Screw them together with a couple slips of paper between them. Don't use bolts, only screws. Lay the assembly on the drill press table with the seam & paper standing vertically, directly under the center of a tiny drill bit (as close as you can eyeball it anyway). Clamp the rear hardwood block to the drill table. Drill a 3/4" hole down through the seam. Half of the hole will be in each piece of wood. Leave the rear block clamped to the table while you partially unscrew the front block from it. Remove the remnants of the paper spacer. Put a little powdered rosin in the two halves of the hole (get a rosin bag at a sporting goods store). Drop your aluminum stock in the hole you just drilled & screw the front block back in place. You've now clamped your stock in a hole that's pretty damn close to perfectly centered under your drill chuck. Drill it to find out just how close. Daniel |
Fairing question... | Tina Marie | Home Built | 5 | July 16th 03 12:18 AM |
