Pegase 101A polar?
Old February 26th 04, 08:38 AM
John Gilbert
Default Pegase 101A polar?
I have not been able to find any information on the Pegase 101A polar
online. Does anyone have one online?
The published references I have found (sailplanedirectory.com, for
instance) quote a L/D of 41:1, and a sink rate, but with no
corresponding airspeeds. Anyone know what they are? How does it
compare to ASW20 in performance?
Thanks,
John
Old February 26th 04, 10:18 PM
Martin Gregorie
Pegase 101a
Maximum L/D: 41 @ 57 kts
Minimum sink: 0.60 m/s (120 fpm) @ 43 kts
I extracted the Min.sink numbers from the flight manual's dry polar,
but think the curve may be for the 101P (fixed gear) as the max L/D
from the curve is 34.7:1 @ 61 kts. The max L/D quoted above (41 @ 57
kts) is from the Sailplane Directory - our club briefing notes for the
Pegase 90 mention 41 @ 55 kts.
Looking at the wet polar (Pegase 101a at 728 lbs, no tiplets) I get:
Maximum L/D: 38 @ 72 kts
Minimum sink: 0.72 m/s (142 fpm) @ 60 kts
ASW-20
The Saiplane directory quotes:
Maximum L/D: 43 @ 65 kts
Minimum sink: 0.59 m/s (116 fpm) - no speed given
Dick Johnson measured the following for the ASW-20 at 759 lbs weight:
Maximum L/D: 41.7 @ 57 kts (same for +0, -6, -9 flap settings)
Minimum sink: 0.56 m/s (110 fpm) @ 40 kts (+8 flaps)
References
You can find Dick Johnson's test reports at
http://www.ssa.org/Magazines/Johnson.asp
I've spent the last two soaring seasons flying a Pegase 90 and have
just bought an ASW-20, so I should be in a better position to make the
comparison in 2-3 months time, weather permitting.
HTH
martin@ : Martin Gregorie
gregorie : Harlow, UK
demon :
co : Zappa fan & glider pilot
uk :
Old February 27th 04, 10:21 AM
Frederic FUCHS
Hi,
Have a look here :
http://planeur.phpnet.org/ivb_112/in...t=ST&f=3&t=768
You don't need an account.
Regards,
Frederic
www.planeur.net
"John Gilbert" wrote in message
om...
Thanks,
John
Old February 27th 04, 02:10 PM
Chris
Have also a look a the nice site from Detlev Hoppenrath (english
http://gliding.hoppenrath.com/index_en.htm, german
http://gliding.hoppenrath.com). He has also a scan from a Pegase brochure
with polars.
http://gliding.hoppenrath.com/Prospe...se/Pegase3.jpg
Cheers,
Christian
Old February 29th 04, 05:18 AM
John Gilbert
Martin,
Min sink at 60 knots, at 728 lbs? The airspeed seems high. 728 doesn't
seem to be a "wet" weight, as empty is about 553?? Maybe this sink
speed is at gross weight?
BTW, many folks have sent at least one version of a polar spreadsheet
with Pegase data, THANKS!! One jpg sent is apparently from an
Idaflieg test flight, at 363 kg (799 lbs), min sink is shown to be
about 46 kt (85 km/hr).
Thanks for all the responses.
John
Martin Gregorie wrote in message . ..
... question omitted...
Pegase 101a
ASW-20
References
HTH
Commercial polar routes? General Aviation 6 January 28th 05 09:03 PM
18m polar curve Alan Irving Soaring 1 December 16th 03 12:45 AM
Pegase (Pegasus) 101A....opinions? Gary Evans Soaring 11 October 8th 03 06:32 PM
Is anyone still interested in CuSoft "Polar Explorer" program for PC? Branko Stojkovic Soaring 1 July 26th 03 02:06 AM
LX 1000 polar calibration Vignaud Frédéric Soaring 0 July 14th 03 06:14 PM
