AL-12: New ultralight sailplane
Old March 24th 04, 12:15 AM
ISoar
Default AL-12: New ultralight sailplane
The US distributor of Aeros hang gliders has announced that the
Ukranian company's ultralight sailplane has had it's first flight.
This craft was built using the wing of Aero's rigid wing hang glider,
the Stalker. It was designed to be towed up by the same tugs hang
gliders use. I wonder what happens when one tries to tow an
ultralight sailplane with the same towplanes we use?
Some specs:
Weight: 80 kilos
Stall speed: 34-40 kph
VNE: 140 kph
Max L/D: 27 at 60 kph
Min sink: .5 - .6 (units not specified) at 45 kph
Details (very few) and photos at
http://www.justfly.com/news/al12info.htm
Old March 24th 04, 12:33 AM
Eric Greenwell
Well, there is "ultralight" and there is ultralight. This one may not
meet the US definition of ultralight if that 80 kilos doesn't include
the rescue system. It still looks like an interesting design for the
microlift category.
The SparrowHawk does meet the US definition of ultralight (less than 155
pounds/70.3 kg), but it has a much higher wing loading (5 to 6
pounds/sqf) than this glider, and can be easily towed with Pawnees, etc.
change "netto" to "net" to email me directly
Eric Greenwell
Washington State
USA
Old March 24th 04, 01:48 AM
Ray Lovinggood
It looks like it could be launched by the 'discus launch
method' used by some radio-controlled gliders. Instead
of a human spinning around, as a discus-thrower does,
I could envision some type of mechanical device rotating
at the proper speed and connected to the wing tip.
Should be an interesting launch!
I'll watch others do it...
Ray Lovinggood
Carrboro, North Carolina, USA
that the
first flight.
wing hang glider,
same tugs hang
to tow an
Some specs:
Weight: 80 kilos
VNE: 140 kph
Old March 24th 04, 02:17 AM
BTIZ
If I did the math correctly.. Vne of 140kph is about 75knts or well within
the lower range of most tow planes like the Pawnee. The key would be what is
it's Va speed or the "max aero tow" speed. That would be the governing
factor.
Summer aero tows out here, you do not want to be above Va (Maneuver) speed,
they can be a rodeo ride. And the max aero tow may be based on the strength
where the tow hook is attached to the aircraft.
BT
"ISoar" wrote in message
om...
Some specs:
Weight: 80 kilos
VNE: 140 kph
Old March 24th 04, 02:52 AM
Netmeister news
My ultralight SparrowHawk tows quite well behind a Pawnee, thank you.
11,100 ft over the mountians from Crystal on Sat. Nice 80 kt cruise and the
smallest diameter turns you've ever seen. Having fun in Cal.
om...
Some specs:
Weight: 80 kilos
VNE: 140 kph
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 06:07 PM
"A Guide to Self-launching Sailplane Operation" available as a download(new edition) Eric Greenwell Soaring 0 March 23rd 04 07:27 PM
Russian jet powered sailplane John Soaring 4 February 12th 04 01:03 AM
Electro-self-launching sailplane clement Soaring 5 September 12th 03 06:03 AM
Ultralight magazine August 1981 Gilan Home Built 0 July 20th 03 05:34 AM
