Todd Pattist wrote:
Eric Greenwell wrote: Clear 2" wide packaging tape is thin and easily applied to the top side, then cut to size. It seems durable in my glider, as does clear "Contact" shelf paper, which works well when both dimensions exceed 2". Two seasons of sun on the clear packing tape I've used seems to cause a separation between the printed label and the tape. I can peel the tape off easily and it separates at all the edges by itself. I've found the clear Contact shelf paper to work better. Perhaps it's the tape or ink I used. The clear Contact has survived years on signs in the trailer, and on the glider. It seems very good. I haven't used the (brand unknown) packing tape as long. It might be weather conditions, too. Maybe there is a new market here for W&W and K&G: high quality Tesa packing tape (1 roll, good for about 400 gliders) and 12" squares of clear Contact (good for one glider) or a roll (good for 87 gliders, or laminating one Flight Manual, so it doesn't dissolve when your water ballast leaks into the baggage compartment where it is kept!). -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
| Thread Tools | |
| Display Modes | |
| Trying to find the Boeing 737-300 Photo Real Panel for FS98(antique;-) | Heiko Brandstaedter | Simulators | 0 | October 7th 04 03:42 PM |
| C182 Glass Panel | Scott Schluer | Piloting | 15 | February 27th 04 04:52 PM |
| replacing plastic panel overlay w/aluminum | Dave | Owning | 7 | January 10th 04 11:52 PM |
| Air Force Academy Review Panel Releases Report | Otis Willie | Military Aviation | 0 | September 19th 03 04:45 AM |
| Air Force Museum forms review panel | Otis Willie | Military Aviation | 2 | August 29th 03 05:41 PM |
