The 'crotch strap' is what used to be known as a 'negative-G'
strap. Usually it works to keep your skull away from the canopy during the bumpy bits of sky; rarely, it helps you in a crash by preventing submarining. However, a single strap is both inconvenient and potentially painful. A better design is a double strap, like an inverted V, but it needs two hard points. Another variation is an upright V, with one hardpoint and some secure way to fasten the ends of the V to the lapstraps rather than the buckle. The conventional 4-point or 5-point harness shows its ancestry from the lapstrap by having the primary mounting [the buckle] on the lapstrap. Would a better design not have the buckle assembly permanently mounted to the [adjustable] negative-G strap and the two lap and two shoulder straps plugging in later ? Ian At 15:00 06 June 2004, Bill Daniels wrote: 'Robertmudd1u' wrote in message ... You may be interested in my latest crotch strap experience. I'm still analyzing my June 2003 accident and the cause. More later on this. The role of the crotch strap is significant and worthy of mention. Dr. Byars, thank you for this interesting and important feedback based on real world experience. The standard line from the German manufactures is that a crotch strap is not needed because the submarining hazard has been taken care of through use of the 'H point' when locating the anchoring point of the lap belts. This system locates the lap belt a bit further forward than in older designs with the aim being to get the lap belt lower on your hips. This is supposed to prevent it from being pulled out of place when tightening the shoulder harness. It does, but I believe the lap belt has to be tightened to an un-necessary degree to get anywhere near the effect the 'H point' is credited with bringing about. My experience is that the 'H point' is not adequate to keep the lap belt from being pulled up when tightening the shoulder straps. This is especially true when flying out west in strong lift at high speed. A crotch strap helps keep you from bouncing around thus providing more comfort and better control. The difference is security in the cockpit is dramatic. I normally retro fit a crotch strap to my gliders and feel a lot safer and more comfortable with its use. This holds true even with my Genesis which used the 'H point' system to locate the lap belt anchor points. Robert Mudd After reading Ed and Robert's posts, I intend to install a crotch strap in my Nimbus. At the very least, it will let me get the shoulder straps REALLY tight without pulling the lap belt up too high. When you are riding 10 - 15 knot mountain thermals with a stiff carbon wing you just can't be strapped in too tight. Bill Daniels |
| Thread Tools | |
| Display Modes | |
| eScrew zen story | [email protected] | Owning | 0 | December 20th 04 08:19 AM |
| Funny story about naval | [email protected] | Naval Aviation | 0 | December 20th 04 04:37 AM |
| Funny story about piloting | [email protected] | Piloting | 0 | December 20th 04 01:34 AM |
| Amazing, True Story and Lessons | jsmith | Piloting | 5 | March 24th 04 04:32 PM |
| PFC Lynch gets a Bronze Star? | Brian | Military Aviation | 77 | August 2nd 03 12:15 PM |
