#28
I recall a picture or diagram of the tool for measuring surface deflection. It may have been in one of Dick Johnsons articles which are or were available at the SSA web site. Iif not it was written up in Soaring. Use a small block of alu or plastic. Dimension are 2" Long 1"wide 1/2 thick. Use three 3/16" round head Nylon machine screws. Install two screws at each corner and one at the middle on the other end. Install dial indicator by drilling a hole in the centre of block as well as cutting a slot for clamping the dial indicator with a screw or look up 1989 Soaring page 35. That was a year after I started flying gliders. Regards Udo |
| Thread Tools | |
| Display Modes | |
| ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell | Otis Willie | Military Aviation | 0 | March 18th 04 09:40 PM |
| Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 06:07 PM |
| Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 04:40 PM |
| Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 03:33 AM |
| An Affordable Homebrue 60 in DS machine | Grant | Soaring | 0 | August 8th 03 04:52 AM |
