1 Amp DC/DC Converter Chip?
Old September 10th 04, 04:57 PM
bcjames
Default 1 Amp DC/DC Converter Chip?
I want to build a 5 Volt power suppply to run my PDA in my
glider from the 12 volt battery. Sometimes I use a 14 volt
battery too, so it needs some input voltage range. I'm
looking for suggestions and a DigiKey part number for a
suitable 1 amp DC/DC integrated power supply chip.
I'd like:
at least 80% efficient
no radio noise
Vin of 10.5 to 16.5 volts
Vout 5 volts
1 amp
low cost
I've looked at the LM2825 and the LTC1174-5, but I'd like to
hear from anyone who's done this.
Thanks
Old September 10th 04, 05:07 PM
Tim Ward
"bcjames" wrote in message
I'd like:
no radio noise
Vout 5 volts
1 amp
low cost
Thanks
Well, good luck. Anything that is 80% efficient and low cost is going to
have some RF noise.
You might look on the National Semiconductor website. They have an online
design tool using their parts -- it gives you a circuit and a parts list.
For some additional cost, they'll ship you a PC board and the parts.
Tim Ward
Old September 10th 04, 06:20 PM
Iwo Mergler
I'd like:
no radio noise
Vout 5 volts
1 amp
low cost
Thanks
Check out Maxim, they tend to be very helpful
with samples. They also have parts with ring
damping circuitry which would help with the
radiated noise.
Another option is to download LTSpice
( http://www.linear.com/software/ ).
That software has a switcher designer
wizzard, you enter your parameters and
it spits out a circuit you can simulate.
Depending on your experience and amount of
effort you want to spend, it may be worthwile
to look into DC-DC converter modules.
Kind regards,
Iwo
Old September 10th 04, 07:08 PM
Jim Vincent
Use a switch mode or buck regulator. Input range at least from 10-14 volts, go
with fixed output 5V.
I build one last year using a chip and a few passives thrown on a circuit
board. Pretty easy. I'd have to dig in the ship, though, to get the Part
Number. Just Google away...many good options from Maxim, etc. Explore Digikey
and others to get all the parts together. Radio Shack won't suffice. Contact
me directly for more help.
Alternatively, you might find an evaluation kit or an off-the-shell solution
like from http://www.soarmn.com/cumulus/
I chose to build my own because I learned a new gizmo! Plus, many years ago I
learned which end of a soldering iron to hold...took a few tries ;-)
Jim Vincent
N483SZ
illspam
Old September 10th 04, 07:59 PM
tango4
http://www.internationalsoaring.org/78hc205.pdf
Needs some attention to good ground circuit, input filter and screening but
work very well - 10 - 30 volt input, 2 amp output.
Ian
Old September 11th 04, 03:19 AM
bcjames wrote in message . ..
I'd like:
no radio noise
Vout 5 volts
1 amp
low cost
Thanks
Hi;
Have a look at the TI integrated switching regulators. This part and
a couple of capacitors will be all you need.
http://dkc3.digikey.com/PDF/T043/1317.pdf
Here is an app note for use in a car:
http://focus.ti.com/lit/an/slta010a/slta010a.pdf
These are nice overload protected parts and will get you going pretty
quickly.
Scott
Old September 16th 04, 06:19 AM
Glen Kelley
Here's an easy approach. Go to
http://www.national.com/store/view_i...LM2675-5.0EVAL
order the National Semiconductor LM2675 demo board ($8!). All you have to
do is wire input voltage and output voltage (5v, 1A) to the board. It is @
90% efficient.
I have been using this converter for my Ipaq this season and it works great.
No RFI that I can tell.
Good luck.
I'd like:
no radio noise
Vout 5 volts
1 amp
low cost
Thanks
Old September 18th 04, 01:56 AM
George Hamilton
Radio Shack sells numerous solid state voltage regulators for pennies.
Easy to use and wire for your requirements.
GHamilton
N7409J
Old September 18th 04, 03:30 AM
COLIN LAMB
The Radio Shack regulators are very inefficient. If you need 5 volts and
run 13 volts input, the 8 volt drop represents total loss. Total power loss
is determined by multiplying the 8 volt drop by the current draw. When
battery power is precious, it is better to use a converter chip to actually
convert the 13 volts to 5 volts - at over 80% efficiency.
The few extra dollars paid to purchase a converter rather than a voltage
dropping regulator is paid back over the life of the equipment.
Colin N12US
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.742 / Virus Database: 495 - Release Date: 8/19/04
Old September 18th 04, 03:46 AM
Eric Greenwell
Colin N12US
To elaborate on what Colin said: to provide 700 milliamp charging
current to the Ipaq, your 12 volt battery must supply:
* Radio Shack voltage regulator at 12 volts: 700 milliamps
at 14 volts: 700 milliamps
* 80% efficient switching regulator at 12 volts: 360 milliamps
at 14 volts: 310 milliamps
My 3835 Ipaq can draw over 900 milliamps while charging and running a
program; my 2215 can draw abut 700 milliamps. It does drop off by about
50% when fully charged.
Eric Greenwell
Washington State
USA
Universal IC Chip Programmer $600.00 OBO NW_PILOT Piloting 1 November 5th 04 03:14 PM
Classic RAS posts: Chip Bearden and "pilot relief" Eric Greenwell Soaring 5 February 20th 04 04:59 AM
24/12 volt DC converter Victor J. Osborne, Jr. Products 1 February 18th 04 03:11 PM
Garmin 430 data chip PaulaJay1 Instrument Flight Rules 6 December 29th 03 05:43 PM
ADC chip detectors CS_Mike Home Built 2 September 3rd 03 07:26 AM
