"Jim Vincent" wrote in message
... I understand that that is the limiting factor to helicopter forward speed.( and why 'Airwolf' could never have worked ) At around 400 kph the forward going blade starts to overcome the amount of control input available I thought it was because the forward blade is approaching supersonic. A one-off special version of the Westland Lynx has the record for world's fastest conventional helicopter; it did 249 mph (401 kph), albeit with special experimental rotor blades. Supersonic flow on the advancing blade is a problem. However a compound helicopter like the Lockheed Cheyenne AH-56 (stub wings and pusher prop in addition to main rotor blade) or the XH-51A (pusher jet engine) could unload the main rotor and do 250-300 mph. I think the fictional Airwolf helicopter used pusher jets in "supersonic" flight. IOW it was a compound helicopter, although this wasn't clearly stated in the TV show. The Bell 222 it was modeled on had stub wings for landing gear. I don't know what the theoretical speed limit is for a compound helicopter, but it's clearly faster than 400 kph. But considering the difficulty of getting a winged plane to efficiently fly supersonic, even if a supersonic compound helicopter was theoretically possible, it's unlikely to be practical. There are better approaches, such as tiltrotor up to about 350 mph (570 kph), and beyond that V/STOL winged aircraft. -- Joe D. |
| Thread Tools | |
| Display Modes | |
| The Meredith Effect | Corky Scott | Home Built | 19 | September 4th 04 05:01 PM |
| Weather and ground effect | Kevin Chandler | Piloting | 12 | April 23rd 04 06:01 AM |
| Date of effect now 1 October 2004 for revised IGC-approvals for certain legacy types of GNSS flight recorder | Ian Strachan | Soaring | 0 | March 15th 04 03:32 PM |
| Wing in Ground Effect? | BllFs6 | Home Built | 10 | December 18th 03 06:11 AM |
| Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder | Ian Strachan | Soaring | 56 | December 2nd 03 09:08 AM |
