On Mon, 22 Nov 2004 09:44:27 -0000, "Ken Reynolds"
wrote: `Roger The maker of the waterproofing should be able to supply you with a material safety data sheet , this will list the main ingerdients in it. The problem there is finding someone at the company "Wilson Leather" who talks to the public and knows what an MSDS is. The public relations people weren't aware of such a thing or that it is required by law. Soooo They are looking for someone who does know. The makers of the viynlester resin should be able to tell you what effect these chemicals may have on a finished layup.Most cured layups are pretty resistant to mild The maker of Dow Derakane will not talk to any one who is using their materials in the construction of an airplane. Hence, it is highly stressed boat or car part. solvents and detergents.Search the net for info on the chemicals in the waterproofing, and also for info on the resin. I'm taking an end run on the resin and talking to some of the chemists "in the know". As I mentioned I have two main concerns. I still have to do additional bonding to this area. The bottom shell has to be bonded to the ribs and shear web in this area. The backing plates and nuts for the elevator hinge bolts also have to be potted. It'd be really inconvenient to have one of those come loose. Then there is the long term effect on the chemical bonds. Near as I can tell that shouldn't be a problem, but this is taking a lot of time to research. Thanks, Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Regards Ken Reynolds |
| Thread Tools | |
| Display Modes | |
| Product to remove oil stains from concrete for painting? | Scott | Home Built | 17 | September 15th 04 07:31 PM |
| Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? | Ron | Home Built | 2 | February 24th 04 05:34 PM |
| Need suggestions for clean butt splice for electrical wires. | Bart D. Hull | Home Built | 9 | January 30th 04 05:28 AM |
| Plan Suggestions | Bill A. | Home Built | 2 | January 9th 04 08:27 AM |
| Builder's Insurance Suggestions | Evan Carew | Home Built | 12 | October 9th 03 07:53 AM |
