Raphael Warshaw wrote:
I'm using a Nonin OEM system which talks to an 8 bit microprocessor. The micro mixes the PulseOX and Pulserate data with the data from my LX1600/Colibri combination into a new NMEA stream so that it is available to my PDA. The PDA can then display O2 levels and raise an alarm if it gets low. I can also log the data to a file. Ian: Neat! Do you have a picture of the OEM oximeter module installation and how the probe cable is routed. I've been looking at the Nonin Bluetooth device and a Bluetooth enabled PDA as a way of doing the same thing without the cable. An added benefit would be that the module could be inside the clothing, which solves the temperature issue. Add a cheap digital pressure sensor and you could monitor your O2 supply as well as the saturation. SPO Medical lists a Bluetooth oximeter to connect with a PDA on their web site, but I'm unable to find a vendor or much information for it. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
| Thread Tools | |
| Display Modes | |
| What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 08:35 PM |
| Reprise - Oxygen concerns | Neptune | Soaring | 20 | May 27th 04 04:27 PM |
| Need oxygen information | Neptune | Soaring | 3 | May 10th 04 07:06 AM |
| Catastrophic Decompression; Small Place Solo | Aviation | Piloting | 193 | January 13th 04 09:52 PM |
