You mean, like, just before the air starts showing through? "For Example John Smith" wrote in message ... Blowout date - 1 day ;-) "Greg Arnold" wrote in message news:xGTpd.175805$hj.6434@fed1read07... How old can trailer tires get before they should be replaced? |
'xactly. I'd rather give a precise, definitive, useless answer than some
more realistic, accurate but possibly useful consultant babble like "it depends". In case Greg's interested-- It depends on how often you tow the trailer. Wheels that are put in motion out on the road regularly will last a bit longer than the ones that just sit on the field. You might get several years out of the tires if you trailer your glider someplace a few times a year. Tires that experience a lot of weather (lots of sun, temperature extremes, moisture, low inflation) but no road use might be crap in a year. It depends on if you bought good quality tires to begin with or wanted to go the cheap route because you don't plan on trailering much anyway. It depends on how averse you are to the extreme sport of "high speed glider trailer blowout handling" and fixing flats by moonlight. Q - Are you a consultant? A - It depends Brent "Bill Daniels" wrote in message news:z43sd.505385$D%.286134@attbi_s51... You mean, like, just before the air starts showing through? "For Example John Smith" wrote in message ... Blowout date - 1 day ;-) "Greg Arnold" wrote in message news:xGTpd.175805$hj.6434@fed1read07... How old can trailer tires get before they should be replaced? |
For Example John Smith wrote:
'xactly. I'd rather give a precise, definitive, useless answer than some more realistic, accurate but possibly useful consultant babble like "it depends". In case Greg's interested-- It depends on how often you tow the trailer. Wheels that are put in motion out on the road regularly will last a bit longer than the ones that just sit on the field. You might get several years out of the tires if you trailer your glider someplace a few times a year. Tires that experience a lot of weather (lots of sun, temperature extremes, moisture, low inflation) but no road use might be crap in a year. It depends on if you bought good quality tires to begin with or wanted to go the cheap route because you don't plan on trailering much anyway. It depends on how averse you are to the extreme sport of "high speed glider trailer blowout handling" and fixing flats by moonlight. Q - Are you a consultant? A - It depends Brent "Bill Daniels" wrote in message news:z43sd.505385$D%.286134@attbi_s51... You mean, like, just before the air starts showing through? "For Example John Smith" wrote in message ... Blowout date - 1 day ;-) "Greg Arnold" wrote in message news:xGTpd.175805$hj.6434@fed1read07... How old can trailer tires get before they should be replaced? Lets just say it is amazing to see the heaps of scrap that various otherwise sensible and careful pilots load their expensive toys into and then blast off into the unknown. Have had the experience of arriving back at the airfield after an hours rather nervous return from a retrieve. When we stopped the driver was honestly surprised to find the bits of melted recap tyre hanging forlornly from the casings. Fortunately the original casings had been good, and were still partially inflated and nominally intact. It had not occured to him that the "cheapest deal available" on tyres because he virtually never used the trailer would not have the same capability as the 225x50 V rated rubber on his executive express, which has the power and weight to ignore anything happening to a single seater in trailer dragging behind. Dumb luck appears to be frequent, but I would advise against counting on it. Buy decent tyres, tow at their rated speed and replace them once they start weathering. It is a lot cheaper than the alternative. |
| Thread Tools | |
| Display Modes | |
| Bad publicity | David Starer | Soaring | 18 | March 8th 04 04:57 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| Tire Stiffness & trailer swaying - resolution | chris | Soaring | 6 | October 26th 03 04:50 PM |
| Need (glider&) trailer transport - Sante Fe, NM > Santa Cruz, CA, late Aug | Eric | Soaring | 1 | August 8th 03 04:21 PM |
| Glider trailer towing | Jeff Landfield | Soaring | 0 | July 21st 03 05:25 AM |
