Desert Sailplane storage
Old December 29th 04, 02:07 PM
Kilo Charlie
Great discussion Bob....thanks! Any chance that your convention talk will
be published somewhere?
Casey Lenox
KC
Phoenix
Old December 29th 04, 02:39 PM
Jim Vincent
Bob, Thanks for your detailed insights. What are your thoughts on the affects
of a fiberglass trailer painted with regular ol' paint instead of gel coat.
Does any UV make it through the trailer to affect the glider within? TIA.
Jim Vincent
N483SZ
illspam
Old December 29th 04, 03:11 PM
Stefan
I don't know whether the UV will make it into the trailer. However, I do
know that the UV will destroy the "regular old paint" rather quickly. In
another life, I owned a wooden boat which was on the water the whole
year without a cover. The UV literally burnt the whole paint away within
two years. And this wasn't "regular old paint", but specialized UV
resistant boat varnish.
Stefan
Old December 29th 04, 10:44 PM
B Lacovara
The technical paper is scheduled to be published at an industry conference next
October. However, I'll be happy to make the SSA presentation available when
it's complete.
Bob
Old December 31st 04, 04:41 AM
B Lacovara
Will be happy to share convention presentation when finished. The formal
technical paper will be presented at a technical conference on October.
affects of a fiberglass trailer painted with regular ol' paint instead of gel
coat.
If the regular ol' paint happens to be urethane it is not much different from
gel coat - almost all white coatings use TiO2 pigment, so the inherent UV
penetration is not an issue. Of course there is a wide range of photo-aging
performance with various types of paints.
One difference between gel coat and paint is the thickness. Because a paint
film is typically thinner than gel coat it will allow more long-wave
penetration (not harmful to polymer surfaces), but may allow more solar heating
inside a trailer. I've never seen any actual data describing the difference, so
don't know how significant the delta might be.
Bob
In Italy - a symposium on saring flight and sailplane construction/design cernauta Soaring 0 September 10th 04 02:26 AM
In Italy - a symposium on saring flight and sailplane construction/design cernauta Soaring 0 September 10th 04 02:16 AM
In Italy - a symposium on saring flight and sailplane construction/design cernauta Soaring 0 September 10th 04 02:15 AM
Ultralight sailplane aerotow liability Caracole Soaring 18 April 1st 04 10:17 PM
Russian jet powered sailplane John Soaring 4 February 12th 04 01:03 AM
