Has a glider ever been found using the transponder radar track?
Old January 19th 05, 01:27 AM
Eric Greenwell
Default Has a glider ever been found using the transponder radar track?
I'm wondering if a transponder-equipped glider would be an aid to search
and rescue people. I've heard that the radar tracks can be obtained from
ATC, but not if S&R people actually do that, and if it can be done in a
timely fashion (less than 24 hours, say).
What are people's experience with this use of transponders for location
of downed aircraft, especially gliders?
If their job isn't any harder than it would be searching for an
ELT-equipped glider, people with transponders could be exempted from
also installing an ELT; people with neither might decide the money is
better spent on installing a transponder.
Eric Greenwell
Washington State
USA
Old January 19th 05, 02:48 AM
Centurion
Unless the aircraft has gone down in a relatively flat area with good
primary and secondary radar coverage, the final resting place of a missing
aircraft is only marginally easier than guesswork. I have flown SAR
missions for missing aircraft west of Sydney, Australia and in one case
after a week of sorties the search was called off. The aircraft was found
1 month later by bush walkers almost 80nm from the last radar return in
heavily wooded and mountainous terrain. Both pilots survived the impact
but died (probably within 2-3 days after impact) of burns and other
injuries sustained in the accident. The ELT was also destroyed in the
post-impact fire, which obviously wouldn't be likely in a glider.
Modern digital ELT's have some major advantages over transponders:
1. they only activate when needed (usually)
2. they have an internal power source
3. they have global coverage (Australia has bugger-all radar coverage)
4. many have built-in GPS to transmit exact location to SAR authorities
5. digital ELT's can also be programmed to transmit registration/owner
details to SAR authorities too.
6. when an ELT/EPIRB transmission is received, it is considered "real" until
*verified* a false +ve. A radar blip that disappears wont initiate an
emergency response until much later (compared to ELT transmission).
In short, if I'm a downed pilot requiring assistance, I'd much rather be
relying on an ELT/EPIRB than some boffin starring at a radar console
Cheers,
James
Kerr's Three Rules for a Successful College:
Have plenty of football for the alumni, sex for the students,
and parking for the faculty.
Old January 19th 05, 03:21 AM
Mark Zivley
The increasing number of self launching and sustaining powered gliders
means there is more chance of a post crash fire fed by the gas on board
and then thereafter by the composites and other materials.
Old January 19th 05, 05:05 AM
Centurion
A very good point. Thanks.
James
Have you noticed the way people's intelligence capabilities decline
sharply the minute they start waving guns around?
-- Dr. Who
Old January 19th 05, 06:00 AM
Eric Greenwell
The possibility is there, but I don't know of any gliders that have
burned after crashing. Does anyone know someone that had a post-crash fire?
I do know of at least a couple gliders that caught on fire on the ramp
due to the canopy, and some electrical fires in the air, but none from a
crash. I think there was 2-22 or 2-33 that ignited the skid during a
landing, and at least started smoking. True?
Eric Greenwell
Washington State
USA
Old January 19th 05, 07:41 AM
John Giddy
Not sure if you meant pure gliders or motorgliders.
I cetrainly know of an RF5 which hit a power line durimg low flying
and burned when it hit the ground.
John G.
Old January 20th 05, 07:24 AM
Duane Eisenbeiss
fire?
Not a crash, but in the early 60's a pilot dropped his cigarette in a 2-22.
The ship started burning on final. The guys got out immediately on landing
and all the fabric burnt off the 2-22.
Duane
Old January 19th 05, 04:06 AM
Eric Greenwell
I wasn't thinking that ATC would notice the lost signal, but that search
and rescue would contact them when they were notified that a pilot was
missing. The trail would be there (presumably), even if the crash was
bad enough to destroy an ELT.
In our relatively flat area, we have complete radar coverage. Perhaps if
a contest official, pilot, etc could determine that the trail end could
be easily, transponder equipped pilots wouldn't need the ELT. Of course,
our relatively flat and treeless area makes searching easier anyway. I
don't recall a pilot being lost in 30 years of contest flying here
(Ephrata). Sometimes they don't call in when they are together with
their crew, but an ELT won't help with that. This situation is improving
as so many people have cell phones now.
Eric Greenwell
Washington State
USA
Old January 19th 05, 03:00 PM
COLIN LAMB
I am a member of Search and Rescue - on the ground end of things. I have
been involved in a number of missing aircraft searches and have my own ELT
tracking equipment. We regularly practice searches in mountainous country.
My experience has been that when we have a report of a missing aircraft and
begin the search, that the sparse information we get is ambiguous and
incomplete. By the time information gets to us, it has been through a
number of relays. Our area is the Coast Range of Western Oregon.
Transponder tracking is undependable and late at best. In most cases we get
no information at all. In one case, involving a fatality, the only useful
information we had was from a "last seen" report from a fellow pilot. We
picked a spot on the map that was likely and sent in ground teams on logging
roads to do a visual search. Weather was bad. We found the aircraft after
2 days, before either the National Guard or the CAP. The aircraft was
destroyed. After searching the wreckage, we found an orange piece of
plastic - similar to the color used in ELTs - the size of a quarter dollar.
In a second fatality, our ground team was out searching when a logger
reported a plume of smoke by his cell phone. In both cases, the aircraft
had ELTs and transponders. In both cases, the aircraft was found by luck
and/or good guesswork.
The ELT is not bullet proof. I believe it is likely to survive a crash if
the pilot does, but no more. The installation is also critical. For
example, with a remote antenna, the coax cable could be severed in a crash,
rendering the entire system useless. I suppose the best solution would be
to have an ejection system and ballistic parachute for the ELT, so that just
before a crash the pilot hits a button to eject the ELT and bring it down to
safety, But I can tell that idea will never fly.
Colin N12HS (Yamhill County Sheriffs Search and Rescue)
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.783 / Virus Database: 529 - Release Date: 10/25/04
Old January 19th 05, 05:21 PM
COLIN LAMB
I might mention that the most useful questions for the searchers a where
was the pilot going; where did he depart from and when was he last heard
from.
Sailplanes would be much more difficult to find, because most of the time
the pilot has no idea where he is going and does not know when he will get
there. Never having searched for a sailplane pilot, I suppose the questions
would be: where is the best lift; where did he hang out and where and when
was he last seen. Would probably ask if there was any areas of turbulence
and the skills of the pilot. From that point on, it is something like
looking for a needle in a haystack.
Colin N12HS
Lawsuit filed over AFA towpilot fatality Stewart Kissel Soaring 20 June 11th 17 03:58 PM
Soaring Seminar - March 19th - ChicagoLand Glider Council ContestID67 Soaring 4 January 7th 05 12:28 AM
Philadelphia Glider Council hosting Region 2 Ground School chipsoars Soaring 0 December 23rd 04 03:11 AM
Seeking Partners for Minden Based Glider Don Johnson Soaring 0 August 31st 03 08:20 PM
FAA Judy Ruprecht Soaring 51 August 25th 03 08:56 PM
