Contact Approach
Old February 15th 05, 06:09 AM
Russ MacDonald
I thought my question was simple.
I have never flown a contact approach in 30 years of professional flying.
I'm trying to learn why. Am I (and all my Texas buddies) missing some big
advantage?
All I am asking is what are the differences in the weather, or the terrain,
or whatever, in the northeast that cause lots of contact approaches instead
of visual approaches? Is it because the weather is not good enough for a
visual approach? It would seem that the weather and terrain are similar to
the Carolinas and Georgia where I have done a lot of flying, yet I never
have heard pilots there requesting contact approaches.
As far as the visual approaches I fly regularly, many are at fields that
don't have any weather reporting (so I know that the contact approach would
not be authorized there). ATC just drops me down to the minumum vectoring
altitude, and tells me to let them know when I have the field, and then they
clear me for the visual. There is no consideration as to whether or not the
field is IFR or VFR. I have flown hundreds, if not thousands of approaches,
like this. It is not uncommon on an attempted visual approach in bad
weather, to call ATC back and tell them I couldn't maintain contact with the
runway environment, and need an approach. This usually happens near the
Gulf due to quickly developing fog.
Maybe what I am asking is for some of you who regularly fly contact
approaches to describe the weather conditions that prompt you to request it.
  #32
Old February 15th 05, 06:58 AM
John Clonts
"Russ MacDonald" wrote in message news:YtfQd.31190$uc.1103@trnddc03...
advantage?
I requested and received a Contact Approach on about my third flight after receiving my instrument rating! I
was being vectored "outbound" for the ILS at Temple. Clouds were scattered-to-broken at about 700 ft AGL, and
visibity was excellent. Once I saw that I could easily get under them and get back to the field, I got the
contact approach and it saved me about 10-15 miles of vectoring. Visual approach would not have worked because
of the cloud clearance. Well I guess you could say it would've "worked" but it wouldn't have been legal
I'm certainly no pro, and I don't "regularly" fly contact approaches, but, there you go...
Cheers,
John Clonts
Temple, Texas
N7NZ
  #33
Old February 15th 05, 01:38 PM
Ron Rosenfeld
On Tue, 15 Feb 2005 05:09:12 GMT, "Russ MacDonald"
For me, it enables me to take short cuts in familiar areas where I do NOT
have the field (or preceding traffic) in sight.
  #34
Old February 15th 05, 01:49 PM
Steven P. McNicoll
advantage?
Not particularly. In my experience contact approaches are requested by
aircraft that happen to spot the field while being vectored for IAPs.
terrain, or whatever, in the northeast that cause lots of contact
approaches
instead of visual approaches? Is it because the weather is not good
enough for a
to the Carolinas and Georgia where I have done a lot of flying, yet I
never
A visual approach requires VFR conditions, a contact approach requires one
mile visibility.
would not be authorized there). ATC just drops me down to the minumum
vectoring
they clear me for the visual. There is no consideration as to whether or
not
the field is IFR or VFR. I have flown hundreds, if not thousands of
approaches, like this. It is not uncommon on an attempted visual approach
in bad
the runway environment, and need an approach. This usually happens near
There is supposed to be consideration as to whether or not the field is IFR
or VFR. The controller must ensure that weather conditions at the airport
are VFR or that the pilot has been informed that weather is not available
for the destination airport. If being vectored for the visual approach
there must be reasonable assurance (e.g. area weather reports, PIREPs, etc.)
that descent and flight to the airport can be made visually.
  #35
Old February 15th 05, 01:52 PM
Steven P. McNicoll
"John Clonts" wrote in message
receiving my instrument rating! I was being vectored "outbound" for the
ILS at
get back to the field, I got the contact approach and it saved me about
10-15
What is the legality? What's the required cloud clearance for a visual
approach?
  #36
Old February 15th 05, 01:57 PM
Steven P. McNicoll
"Ron Rosenfeld" wrote in message
You don't have to have the field in sight for a contact approach but you do
have to be separated from other IFR traffic. If you have preceding traffic
in sight visual separation can be used, but preceding traffic that you don't
have in sight will require denial of the contact approach.
  #37
Old February 15th 05, 02:00 PM
On Mon, 14 Feb 2005 19:37:07 -0500, Ron Rosenfeld
On Mon, 14 Feb 2005 21:19:48 GMT, "Steven P. McNicoll"
The requirement is for VFR conditions, only in a surface area are VFR
conditions 1000/3.
Your answer is not responsive to my question. As I quoted, the requirement
in the AIM is for 1000/3 -- NOT for VFR conditions.
I think this may simply be an illustration of why one has to be
careful in using the AIM.
  #38
Old February 15th 05, 02:56 PM
On Tue, 15 Feb 2005 07:38:28 -0500, Ron Rosenfeld
It's also often useful just to get lower before you have the field in
sight.
Although I find it more useful in unfamiliar areas than familiar
areas.
  #39
Old February 15th 05, 02:59 PM
On Tue, 15 Feb 2005 12:57:28 GMT, "Steven P. McNicoll"
How far away does this "preceding traffic" have to be in order to get
a contact approach?
As a matter of fact, it would be interesting to know what exactly are
the separation rules for contact approaches.
  #40
Old February 15th 05, 05:33 PM
Russ MacDonald
IFR
etc.) that descent and flight to the airport can be made visually.
They descend me to MVA at my request, and once I call the field in sight,
they always clear me for the visual. If I don't see the field, I tell them,
and they climb me back up and clear me for an approach. They basically
leave the decision to me as to whether or not to go for the visual. They
don't seem to have any concern about whether the field has 1 mile visibility
or not (although, I don't think I could see the field if the visibility was
less than a mile).
After I read several posts discussing the contact approach, I began
wondering if requesting one might buy me anything. I just can't think of
any situation where I would be able to see something I recognized other than
the field, and still want to go for a non-instrument approach.
GPS approach question Matt Whiting Instrument Flight Rules 30 August 29th 08 04:54 AM
Contact approach question Paul Tomblin Instrument Flight Rules 114 January 31st 05 07:40 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 12:13 PM
