WAAS Airport Costs?
Old February 17th 05, 07:44 AM
Scott Moore
Bob Gardner wrote:
http://www.avweb.com/newswire/10_18a.../187168-1.html
This will link you to an article that describe LAAS as being delayed for
quite a while. Don't hold your breath.
Bob Gardner
The principle problem with LAAS is that the government has a schedule to replace
ALL of the GPS sats with higher precision versions. I.e., the precision of GPS
is going up, without any particular new infrastructure going into place on
the ground or in the air. Which means that by the time any LAAS program got
on its feet, standard GPS, and presumably WAAS, might well offer the same
capability.
Samiam is Scott A. Moore
Personal web site: http:/www.moorecad.com/scott
My electronics engineering consulting site: http://www.moorecad.com
ISO 7185 Standard Pascal web site: http://www.moorecad.com/standardpascal
Classic Basic Games web site: http://www.moorecad.com/classicbasic
The IP Pascal web site, a high performance, highly portable ISO 7185 Pascal
compiler system: http://www.moorecad.com/ippas
Good does not always win. But good is more patient.
Old February 17th 05, 07:52 AM
Scott Moore
I have the ear of some local government development people, who are
contemplating upgrading some airports. Money is tight, so an ILS is
probably not under consideration. So, I want to recommend to them
checking into a WAAS installation. Does anyone know what the prices of
such equipment for an airport are, which companies are selling them,
and how much it costs to get the FAA to then create a WAAS IFR
approach?
Sincerely,
/iaw
As the AOPA has stated, WAAS will first be used to offer controlled
descent on standard approaches, an alternative to "dive and drive"
stepdowns, which makes it completely legal. There is no requirement
for HOW you get down to the runway, just as log as you observe minimums,
which means a likely mention in the AIM that you are supposed to keep
an eye on your standard altimeter.
I don't think the outlook for WAAS aproaches is rosy. What will happen
is WAAS approaches that have minimums just as bad as the normal GPS
approaches. To get more would require new lighting, runway marking,
and FAA surveys. And recall that the FAA does not just survey the
runway once, they have to do it regularly, with an expensive monitoring
aircraft. Runway markings are not a trivial subject. A lot of fields
have runways so bad they would have to get resurfaced just to be
properly painted.
I think it will happen, but the AOPA seems to be spreading this idea
that we will get 250 minimums overnight. This is going to be a long
process.
Old February 18th 05, 01:50 PM
Eclipsme
"Ron Rosenfeld" wrote in message
news
On 16 Feb 2005 17:02:23 -0800, wrote:
this does not look like great news for WAAS or LAAS. where is WAAS
actually functioning right now? (is there a map of applicable areas?)
or is it "so much for the heavily advertised WAAS features of the
GNS480"?
WAAS usually covers most of CONUS, southern CANADA, northern Mexico and
Caribbean islands with accuracy sufficient to provide LPV approaches.
See
http://www.nstb.tc.faa.gov/vpl.html for a map that is updated every
six
minutes.
What is the 'vertical protection level' on the map? Is this the altitude (in
meters!) that waas is guaranteed? If so, it looks like over 120 meters
coverage is everywhere. This can't be, can it? What am I missing?
Harvey
Old February 18th 05, 03:01 PM
Dave Butler
See http://www.nstb.tc.faa.gov/vpl.html for a map that is updated every
six
minutes.
From the WAAS Terms & Definitions link at the bottom of the page:
Vertical Protection Level (VPL). The Vertical Protection Level is half the
length of a segment on the vertical axis (perpendicular to the horizontal plane
of WGS-84 ellipsoid), with its center being at the true position, which
describes the region that is assured to contain the indicated vertical position.
It is based upon the error estimates provided by WAAS.
Old February 18th 05, 04:03 PM
news
WAAS
areas?)
GNS480"?
and
approaches.
See
every
six
minutes.
altitude (in
meters
Harvey
VPL is what the receiver compares against a VAL (alert limit) to
determine whether or not to raise the Integrity flag. The VAL for
LNAV/VNAV and LPV is 50 meters.
Regards,
Jon
  #30
Old February 18th 05, 07:16 PM
Ron Rosenfeld
I'm not sure what you are missing. A map reading lesson? Bad color
rendition on your monitor? Perhaps some other issue when you downloaded?
At the present time (1:13 PM EST) it looks like the LPV contour includes
virtually all of CONUS, Alaska, southern Canada, Northern Mexico, Caribbean
and inside that contour the VPL is 50M or less. For about 99% of the US it
looks as if the VPL is around 20M.
NAS and associated computer system Newps Instrument Flight Rules 8 August 12th 04 06:12 AM
N94 Airport may expand into mobile home community, locals supportive William Summers Piloting 0 March 18th 04 04:03 AM
Rules on what can be in a hangar Brett Justus Owning 13 February 27th 04 06:35 PM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Piloting 16 January 20th 04 05:02 PM
