wing levelers
Old February 25th 05, 05:51 AM
Montblack
("Morgans" wrote)
snips
We are not sure how to detect the very earliest initial wing tip movement
or drive the small trim type motor and would appreciate some thoughts or
site recommendations to investigate.
The idea of a ball bearing in a tube is not even close. Ever hear of the
graveyard spiral? It is what killed Kennedy. (not the president) In
such
a spiral, you experience several 360 degree turns, diving steeply enough
that vertical descent rates of 10,000 feet per minute (if the plane holds
together) are possible. Still, the ball in the tube would stay right in
middle. One G all the way.
You need a gyroscope, or an electronic equivalent. Some have played using
very sensitive GPS antennae in the wingtips.
Best advice? Trim the plane, stay awake and fly it, or BUY an autopilot,
or
wing leveler. Or google wing leveler.
Automotive world is using electronic stability-control (ESC) systems with
documented success. The article says the system used a decade ago wasn't
very good, but they've come a long way since then.
http://www.detnews.com/2005/autoscon.../F01-91164.htm
http://www.caranddriver.com/idealbb/...?topicID=60884
I'm guessing some variant of this is what you'll eventually cobble together
in your garage.
Montblack
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 09:40 PM
Wing tip stalls mat Redsell Soaring 5 March 13th 04 06:07 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 04:40 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 03:33 AM
An Affordable Homebrue 60 in DS machine Grant Soaring 0 August 8th 03 04:52 AM
