RAH'er has forced landing
Old December 22nd 04, 09:45 PM
Matt Whiting
Bob Chilcoat wrote:
Matt's response gives me an thought. Has anyone ever tried a torque
converter by itself as a PSRU? Seems like it might solve a number of
problems, be relatively light, and not subject to wear. Just a thought -
I'm sure there would be lots of new problems.
I suspect that heat generation would be the killer for a typical auto
unit. Also, I don't know if the lock-up clutch would work at the torque
levels required in AC use. Probably other problems as well, but I'll
bet heat generation would be a biggie, especially if the lock-up clutch
couldn't be used. And if the lock-up could be used, you'd have no
reduction ratio, which means you'd no longer have have PSRU, just a PU! :-)
Matt
"bush flying" in the suburbs? [email protected] Home Built 85 December 29th 04 12:04 AM
Cessna Steel Landing Gears, J-3 Seat Sling For Auction Bill Berle Home Built 0 February 19th 04 07:51 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 03:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
Off topic - Landing of a B-17 Ghost Home Built 2 October 28th 03 05:35 PM
