Need Information To Do A 150 Hp Conversion On My C-150
Old March 1st 05, 12:47 AM
In rec.aviation.owning Newps wrote:
: Don't know what altitude you're talking about but at 7500 and 20 squared
: you are looking at 9 gph. At 15 inches and 2000 you will get about 6.5
: gph. At this point the nose will be pretty high and you will only be
: getting about 95-100 MPH IAS. To get to 5.5 gph wouldn't be any fun at
: all. If you have to have 5.5 then sell the plane and get something that
: can reasonably do that.
He didn't ask how to make it fun... just if it was possible to fly a 182 at
5.5 gph. I answered that it most likely was. Truth be told, if you're after pure
fuel economy, you'd want to run oversquared as much as possible, too.
: On the big bore Continentals you need to be below 65% before you try
: that. Plus having a carbed engine makes LOP impractical.
LOP on a carb'd engine is difficult/unlikely. Running at peak (as long as
your CHT's aren't high) is fine as well... as long as your power is low.
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Old March 1st 05, 03:01 AM
nrp
Max Conrad (ferried Pipers all over the world in the 40s and 50s) ran
fully leaned & with full carb heat when he was in his max range mode.
Do you know of any reason not to, assuming a low power setting? It
would improve the mixture distribution, something the O-470s are
notoriously poor at. It would also reduce the inlet air density,
allowing things to operate with less pumping loss.
nrp
Old March 1st 05, 02:57 PM
In rec.aviation.owning nrp wrote:
: Max Conrad (ferried Pipers all over the world in the 40s and 50s) ran
: fully leaned & with full carb heat when he was in his max range mode.
: Do you know of any reason not to, assuming a low power setting? It
: would improve the mixture distribution, something the O-470s are
: notoriously poor at. It would also reduce the inlet air density,
: allowing things to operate with less pumping loss.
Unless the CHT's get too high in that configuration (causing poor valve
cooling and cylinder badness), there's not much that says it's bad except:
- No filtration of the air with carb heat. Shouldn't be a big deal in cruise (unless
you have a *really* dirty cowling).
- If flying in cold enough weather, you could get carb ice when normally ice crystals
would flow through unmelted. (I generally don't like to use carb heat until I know
it's necessary)
- Sudden power requirement will cause the engine to falter... get used to a quick red
knob, then throttle.
The real disadvantage of the arrangement on my fixed-pitch plane is 65% is
only obtainable at that mixture up to about 7000-8000'. "Best power" of 50 ROP will
get you 75% or so at that altitude.
-Cory
* Cory Papenfuss *
Old March 1st 05, 03:43 PM
Newps
On the 470's, in cruise, you give it whatever carb heat gets you a carb
temp of 40-45F. Running at full carb heat makes no sense whatsoever.
Old March 1st 05, 06:34 PM
nrp
carb
Why not? Using full carb heat would seem to promote better mixture
distribution. The reduced charge density would allow you to run a
higher manifold pressure for the same mass flow, reducing the pumping
loss for a given power setting.
Obviously aggressive leaning probably to at least peak would be
desirable, although who knows where the non-instrumented cylinders
would be running.
I'd be a little concerned running partial carb heat as there would
possibly be a considerable temperature gradient in the air intake
system, given how the carb heat is crudely modulated with that
humongous flapper valve. In other words, some cyls might get a hot
mixture, and some might get cold mixture.
This is assuming the purpose of all this is to reduce the fuel
consumption to get maximum endurance or range under low power settings.
I don't think cyl temp would be a limiting factor.
I don't normally fly my 172M this way (w carb heat always on), but if
it was a question of making it or not, I'd sure use it.'
Thoughts of others?
Most pilots don't know how to get the absolute maximum range or
endurance out of their aircraft.
Old March 2nd 05, 03:24 AM
Aaron Coolidge
I find that I can run my Cherokee's O-360 LOP quite effectively using full
carb heat. Attempts to do so without carb heat lead to unacceptable engine
roughness. With the carb heat on, I can reduce the RPM down several hundred
RPM from peak RPM with good smoothness. Without the carb heat, the RPM
peaks as the mixture gets leaner, then as the RPM begins to drop the engine
gets progressively rougher.
I have not run the engine LOP for any appreciable length of time as I have
no CHT or EGT instrumentation. I have done it for a minute or so to see if
it is possible.
Aaron C.
Old March 2nd 05, 01:23 PM
In rec.aviation.owning Aaron Coolidge wrote:
: In rec.aviation.owning wrote:
: : The real disadvantage of the arrangement on my fixed-pitch plane is 65% is
: : only obtainable at that mixture up to about 7000-8000'. "Best power" of 50 ROP will
: : get you 75% or so at that altitude.
: Cory, this I don't understand. You don't have to run WOT to use LOP. Or, are
: you saying that you can't get over 65% LOP above 7000'? The maximum possible
: power from a non-turbo engine at 7000' is 75%, perhaps that's what you're
: saying?
: Aaron C.
Basically, I'm talking about two slight variations on the general rule is that
max power possible in a non-turbo plane is 75% at 8000'. The first is that I'm
running a fixed-pitch prop, so I don't have independent control over the prop speed.
The second is that the 75%@8000' number is at best power mixture setting... 50 ROP.
At peak/LOP, box the torque from the engine decreases (less power per bang), *and* the
propeller slows down (less bangs/time). I'd say probably about 5% each for both
issues... so I can't run 65% at above 7000-8000'. The corollary to that is that above
7000-8000', I can do *anything* to the red knob and not hurt anything.
I flew back from Ohio awhile back on a great VFR day with a tailwind.
Climbed up to 10000', pulled back to about 50% power (110mph IAS) and flew for 2 hours
with about 110kt GS. I couldn't put more than 11 gal of cargas in the tank when I got
there, and I got to enjoy a great flight.
* Cory Papenfuss *
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 28th 04 12:49 AM
ANN: SoaringPilot 1.9.8 Mark Hawkins Soaring 0 April 21st 04 06:09 PM
Japanese firm sold Libya uranium conversion plant Dav1936531 Military Aviation 2 March 17th 04 04:47 PM
Mini 500, Helicycle, Turbine, Joe Rinke, Rinke Aerospace, Rick Stitt, Conversion, Kit TurbineMini Richard Rotorcraft 0 January 16th 04 12:48 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 13th 03 12:01 AM
