Have you checked the pivot rod for the cowl flaps? they wear and bind.
Michelle Jim Burns wrote: I've got a problem with a cowl flap cable in our Aztec. The other day when landing, I opened the cowl flaps to 1/2 on final, then full open after landing. I noticed when going from 1/2 open to full open while on the ground the left cable seemed stiff. I tried closing the flap, then reopening and it got worse immediately, then quit moving completely. The flaps themselves move freely. I've disconnected the cable from the torque tube on the flap end and it seems free, no binding, but I can only pull or push the cable in or out 3/8-1/2 inch, just enough to make me believe that it's not bound on that end. I've popped the covers off the slide tubes on the cable and sprayed them with LPS 1. The slide tubes seem free, they both spin around the cable easily. Now I'm looking at the control handle end of the cable. I can not sense any binding around the cable connector or in the slide tubes. I can not see where the handle is binding or jammed but it will not budge. My next step is to disconnect the handle from the cable. Then pull the cable out the bottom of the belly to see if we can move the cable inside the sheath. This all happened after we flew 5 hours from Atlanta, stopped for fuel, then a short 20 minute flight to our home base. At the fuel stop the cowl flap worked fine. Opened on landing, 1/2 closed after take off, full closed in cruise, then opened to 1/2 at our home base with no binding noticed. Any ideas?? Anybody ever have anything like this happen? Thanks Jim |
| Thread Tools | |
| Display Modes | |
| Archer Cowl needs work - Advice? | Bob Chilcoat | Home Built | 26 | March 4th 05 03:26 AM |
| PA28-181 - Stuck Mike - King Silver Crown | Roy Page | Owning | 2 | October 29th 04 04:36 AM |
| Space Elevator | Big John | Home Built | 111 | July 21st 04 05:31 PM |
| best Winch cable? | yo | Soaring | 2 | April 2nd 04 04:47 PM |
| cable splicing(w/o ferrules) | Andy Davey | Soaring | 2 | March 19th 04 01:49 PM |
