Lx 1600 vs Borgelt 50
Old March 26th 05, 01:35 AM
Glen Kelley
Kevin, good stuff, thanks.
What is it about the digital presentation that you prefer. Does the LCD
display provide good contrast in direct sunlight?
Since I have a VL, I thought the comment about the Colibri working better
with the LX was interesting. It appeared from the spec sheets that the LX
series could get the proper info from a VL. Is there more to the picture?
Thanks again.
Glen
"Kevin Christner" wrote in message
I flew with the LX1600 last season. Most of the settings have to be
adjusted on the iPaq. This is either a pro or con depending on how you
look at it. One major benefit if you have a glider with 2 sets of
wingtips is its much easier to change the polar than on the B50. On
the B50 you have to open the case. Both are very good as far as the
vario goes. Having flown with both the LX and the B40, I prefer the
digital meter of the LX over the Borgelt analog meter.
The LX has its own final glide functions that you may find useful. Its
best to use a Colibri with the LX, where a Volkslogger would probably
be your best choice for the B50. This also might influence your
decision.
Kevin
Borgelt B100 soaring flight computer for sale [email protected] Soaring 0 January 20th 05 02:07 AM
Inquiry about 2nd hand value borgelt B100 and capabilities goneill Soaring 3 October 4th 04 12:56 PM
prop for 1600 cc VW dave Home Built 1 August 12th 04 06:57 AM
Borgelt website update Mike Borgelt Soaring 6 December 1st 03 08:47 PM
Borgelt B50 and B57 Mal Soaring 1 October 26th 03 02:42 PM
