#21
"The point loads in fiberglass airplanes are carried through strong
bulkheads, bonded very well to the body. I don't think what your describing has that. If the use of a single layer of wood is used to be the core, instead of foam, and the same thickness of fiberglass is applied, as it would be in the fiberglass and foam plane, there should not be a problem. Is this the intent?" Yes! The cedar strips are simply space, rather than strength. The rigidity comes from the 1/4" thickness of the cedar strips, plus the thickness of the multi-layer epoxy coverings. My kayak has 3 layers of cloth on the exterior, plus epoxy resin..The cedar strip is used for beauty and the "plastic" ability to conform to compound curves. The strength comes for the thickness of the cedar times the layers of epoxy - really like a foam aircraft. Although additional strength could be gained by cross laminating 2 layers of cedar strips, it would also add to the weight - and the change of delamination between layers may increase. Just as in foam airplanes, bulkheads of other means of transferring stress from a single point to a much larger area are necessary. I have built a stitch-n-glue boat, also, but could never get the beautiful compound curves that I could get from the cedar strips. There is a limit to the bending. I do think, though, that it would not be difficult to simply make a mold of the shape desired and take very thin skins and make your own plywood, conforming directly to the desired shape, much like the paper mache ugly animals we made in grade school. Compound curves allow great strength with thin materials. Colin |
| Thread Tools | |
| Display Modes | |
| Nut/thread securing compound | nauga | Home Built | 7 | April 22nd 04 08:56 AM |
| Randolph Wing Walk Compound | Larryskydives | Owning | 7 | March 7th 04 10:44 PM |
| Plywood | Kathi Jo | Home Built | 3 | January 12th 04 11:48 PM |
| Somebody Terrified of Compound Curves ---- Or Just Lazy | Larry Smith | Home Built | 8 | October 31st 03 03:40 PM |
| Substitute for Mahogany plywood | Kelvin & Janice Rempel | Home Built | 1 | September 5th 03 09:02 PM |
