"Morgans"
: "COLIN LAMB" wrote I have built a number of cedar strip canoes and kayaks, and the process is simple and beautiful. The same technique could be use for aircraft. I have taken my canoe through rapids, over small water falls and survived collisions with rocks. The same technique should work for a lightweight aircraft. One problem is that for an airplane, there are bunches of point loads, like the spar, engine, and landing gear. There are also some wicked bending moments involved. If you canoe breaks, you go swimming. If you airplane breaks, you...... Well, in this case, there's no engine, of course, unless you count the mounting of the pilot as a gravity engine. The loads for the gear, strut points, wing attach and boom are all distributed through formers, which are in turn held in place by the skin. The alternative is 1/16 ply wrapped between each adjacent set of formers and scarfed to it's neighbor, which doesn't appear to be any stronger than a planked setup which basically amounts to a whole lot of stringers. They'd have to be kept thin to keep the weight down, of course. |
| Thread Tools | |
| Display Modes | |
| Nut/thread securing compound | nauga | Home Built | 7 | April 22nd 04 08:56 AM |
| Randolph Wing Walk Compound | Larryskydives | Owning | 7 | March 7th 04 10:44 PM |
| Plywood | Kathi Jo | Home Built | 3 | January 12th 04 11:48 PM |
| Somebody Terrified of Compound Curves ---- Or Just Lazy | Larry Smith | Home Built | 8 | October 31st 03 03:40 PM |
| Substitute for Mahogany plywood | Kelvin & Janice Rempel | Home Built | 1 | September 5th 03 09:02 PM |
