I use scenario #3. In the UK it is mandatory to have
a fuse 'as close to the battery as possible' to protect the whole system and I use a 3 amp fuse. There is also a seperate fuse, rated to the individual instruments mainly to try and prevent one single instrument taking the whole system down. That does not always work as the only problem I have had was with a fault in the distribution box/power supply for the PDA/Logger/GPS. All the output leads from the box are fused but a fault in the box blew the main battery fuse. The power requirements of all my instruments are well below 3 amps. A standard battery is 7ah a current draw of 3 amps would flatten the battery in 2.5 hours (max) and this is one of the reasons why we are so set against adding further avionics such as transponders over this side of the pond. At 03:00 20 April 2005, Jack wrote: I really like scenario # 3. Most of the time you'd be OK with just the devices fused, but would you want to have an electrical fire in the glider at altitude, with oxygen floating around in the cockpit? I have mine fused as close to the battery as possible. I'm a telecom manager for a class 1 railroad, and we do all our installations with this fusing method. We have a lot of specialized electronics in locomotives and vehicles. We don't want electrical fires in any of those, either. Be safe up there... Jack Womack |
Don Johnstone wrote:
The power requirements of all my instruments are well below 3 amps. Have you checked the amperage while the radio is transmitting? A glider with a GPS (.2 -.3 amps), PDA (.4 to .8 amps), vario, and a good radio transmitting (Becker 4201 2+ amps) can draw 3 amps, so you might be closer to the fuse rating than you think. And if you turn on the T&B (.7-.9 amps), you will almost surely exceed 3 amps during transmission. I suggest you go to at least 5 amps, since you use smaller fuses to protect the individual devices. This will also reduce the voltage drop across the fuse, a good thing. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
| Thread Tools | |
| Display Modes | |
| Question for Jim Wier (or other electrical guru) | Mike Rapoport | Owning | 39 | January 10th 05 07:01 PM |
| Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | Home Built | 6 | October 15th 04 09:51 PM |
| Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | General Aviation | 0 | October 12th 04 06:11 PM |
| Wire for homebuilts. | clare @ snyder.on .ca | Home Built | 9 | March 25th 04 06:51 PM |
| Coalition casualties for October | Michael Petukhov | Military Aviation | 16 | November 5th 03 12:14 AM |
