Corrosion Proofing
Old April 22nd 05, 01:03 AM
Roger
On 21 Apr 2005 03:34:21 -0700, "Denny" wrote:
They are both good prducts and work as advertised... ACF50 seems to
make less mess... If you are happy with X, I wouldn't change... I was
just making the point that the exposed metal surfaces in an assembled
airplane are not the major site of corrosion, it is the fayed joints,
and coating them on the outside with paint will not protect them... I
spoze one could spray Variprime and also use ACF50, seems redundant
though...
They tell me that good old LPS-2 works quite well.
You can tell if they did a good job if you take the plane out and let
it set in the sun. It'll drip for about two weeks.
www.rogerhalstead.com
denny
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 04:36 AM
Non Chromate Anti Corrosion and Paint Prep X-it Prekote? All Thumbs Home Built 7 May 5th 04 05:21 PM
Corrosion Protection on Alluminum Sheet Aircraft? DL152279546231 Home Built 6 February 10th 04 06:10 AM
How much corrosion is too much? Carl Orton Owning 5 February 2nd 04 02:31 AM
Corrosion X Applicators Hankal Owning 5 July 7th 03 07:07 PM
