Question - Regarding Canard Pushers...
Old August 7th 03, 06:46 AM
Tilt
Default Question - Regarding Canard Pushers...
Hi,
I'm new to this newsgroup. I have a couple of questions.
Sometime within the next 10 years (hopefully a bit sooner), I will begin a
homebuilt project. Myself and a couple of friends plan to go in on a project
together. Basically splitting the costs and the final product. 2 of us do
not yet have our pilots licence and one is currently a Canadian Forces
fighter pilot. We've only had casual conversation about this project so far.
I've decided to start laying the ground work for this long term project.
We all really like the idea of a canard pusher design. 4 seats are also
desired. Details after that have not been discussed. But one thing that
popped up was the control stick position. I've noticed, while surfing the
net looking at Velocity's and Cozy's, that the stick is a side mount. I
would prefer a center mount stick and I know my fighter friend would want
the center stick. Does anyone produce a kit, along these lines, with a
center mount stick? Are there any other choices out there for a 4 place
canard pusher?
I've found some rough figures on costs of Velocity pushers. What are some
potential final tallies for Cozy's?
Lastly, what are some recommendations, for homebuilt canard pushers, that
any experts here can give?
Thanks,
Lyle
Old August 7th 03, 11:55 AM
Kevin Horton
the net looking at Velocity's and Cozy's, that the stick is a side
mount. I would prefer a center mount stick and I know my fighter friend
would want the center stick.
You might want to wrangle a flight in a canard with a side stick before
you write off the concept. It does work reasonably well, at least on the
Gyroflug Speed Canard that I flew.
4 seat canards are not the sort of aircraft you do aerobatics in, so you
don't need the leverage that a long centre stick gives you.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://go.phpwebhosting.com/~khorton/rv8/
Old August 7th 03, 03:48 PM
Big John
Kevin
Note your Fighter Pilot's druthers.
With a side stick you can't fly with your knees while you do other
important things with ur hands.
Big John
Retired Fighter Pilot
On Thu, 07 Aug 2003 10:55:56 GMT, Kevin Horton
Old August 7th 03, 09:39 PM
Snowbird
Big John wrote in message . ..
Kevin
Well, one could install a simple wing-leveler/GPS tracker
autopilot, not?
Depending upon the plane's mission, which might be
"goin' places" if 4 seats are a must, an AP can be
highly desireable.
Sydney, whose autopilot is in Georgia as we speak
Old August 7th 03, 11:24 PM
RobertR237
In article , Big John
writes:
Kevin
Big John
That's what Autopilots are for.
Bob Reed
www.kisbuild.r-a-reed-assoc.com (KIS Builders Site)
KIS Cruiser in progress...Slow but steady progress....
"Ladies and Gentlemen, take my advice,
pull down your pants and Slide on the Ice!"
(M.A.S.H. Sidney Freedman)
Old August 7th 03, 11:29 PM
Kevin Horton
On Thu, 07 Aug 2003 10:48:51 -0500, Big John wrote:
Kevin
Big John
also desired. Details after that have not been discussed. But one
thing that popped up was the control stick position. I've noticed,
while surfing the net looking at Velocity's and Cozy's, that the stick
is a side mount. I would prefer a center mount stick and I know my
fighter friend would want the center stick.
the Gyroflug Speed Canard that I flew.
I got lots of hours holding sticks between my knees too. I would prefer a
centre stick too. But a properly built and rigged canard should be able
to keep right side up once you've got it trimmed, I would have thought.
So you should be able to release the stick for short periods if you really
need both hands.
I'm not aware of any four place canards with centre sticks. I suspect it
would be a very large job to cobble a centre stick onto one of the four
place canard designs. You would need quite a few bell cranks, etc, and
the number of pivots could lead to excessive friction, if you weren't real
careful with the design and construction.
Ottawa, Canada
Old August 8th 03, 12:22 AM
Tilt
I'm seeing this may be the case. We arn't getting real serious yet, but I
want to start researching this info now. My friends and I would certainly
prefer a stick between the knees. My fighter friend has flown this way since
the start of his flying career. I myself like that arrangment too. Maybe we
need to look at other homebuilt designs. We would like the craft to have
some light aerobatics abilities. Nothing real heavy...none of us wants to go
off and join the Air Show.
I did find a web site of a dude building an SQ-2000 canard pusher. His
cockpit was set up with 2 yokes. This leads me to think it wouldn't be hard
to set up a center (between the knees) stick.
Any SQ-2000 owners out there want to enlighten me?
Cheers,
Lyle
need both hands.
Ottawa, Canada
Old August 8th 03, 04:23 AM
Ernest Christley
What is the reasoning behind a pusher? If you want to get started
sooner than later, then take a look at the Dyke Delta. It's plans
built. $200 to get started, and then pick up tubing as you go along.
----Because I can----
http://www.ernest.isa-geek.org/
Old August 8th 03, 04:49 AM
smf
I have 500+ hours in a Q-200 (center stick) and am currently flying a
Glasair II (stick between the legs).
The position of the stick isn't an issue for me.At one time I thought it
was. I fly the Glasair left handed and am quite comfortable with it.
So many other things are issues!!! But certainly not the position of the
stick. The issues come and go as these machines are evolving, Issue at hand
is change both mags and harness or go with single electronic ignition.
It's always something!!!
Steve
"Tilt" wrote in message
. ca...
Hi,
project
far.
canard pusher?
Thanks,
Lyle
Old August 8th 03, 05:10 AM
Richard Lamb
Steve,
How does the Q-200 fly?
Have you ever written up the handling characteristics?
Richard
Steve
Tailwheel question Steve B Aerobatics 4 January 30th 04 03:35 AM
Hinges under stress - mechanical engineering type question Corrie Home Built 21 August 6th 03 08:49 AM
question on intercoms for my new homebuilt w b evans Home Built 1 July 23rd 03 12:57 AM
Canard static port location Paul Lee Home Built 1 July 12th 03 02:55 AM
Pitts Screw Question VTflyer Home Built 1 July 2nd 03 11:02 AM
