wrote: 2NO wrote: I get: "Valid waypoints reached in the present flight trace (IGC-file) are printed in green. The flight claim is complete only when all waypoints are printed in green. Suggestions will be made by the server only if the flight trace approaches a declared waypoint to no more than 2.5km. There is no fix in the IGC-file with your finish time." I have exactly the same problem (Cambridge Model 10). I have reviewed the raw file and confirmed that there are indeed B record fixes in the file corresponding to the fixes that OLC is showing as no good. I have verified multiple times that there is in fact a fix in the IGC file with exactly the finish time... Ditto. I have tried - CAI file direct to See-You 2.85. I have tried CAI file + conv-cam to create new IGC file then the OLC utility cai2igc to append the G records to the new IGC file & several variations thereon. All equally hopeless and resulting in the same errors as you have. I have wasted hours on this and I'm giving up unless someone has the process down. I had a very similar problem last year. With the help of the OLC team, it was determined that the file transfer to OLC was incomplete, so many B records were missing on the file on their system. I tried to upload the file again and was rebuffed with the message "Flight File already in OLC" or some such ... it wouldn't replace the partial file with a new copy. Again, the OLC team provided a trick that allowed me to eventually be successful. The trick is to change the name of the .igc file to be uploaded by bumping up the flight sequence number for the flight date. That's the digit in the eighth character position in the file name. Example: change ymdCxxx1.igc to ymdCxxx2.igc OLC treats the new file as if it is a new file for a new claim, giving a new shot at getting the complete file uploaded. |
| Thread Tools | |
| Display Modes | |
| New File Library Email Service | Tom Allensworth | Simulators | 2 | July 19th 04 11:33 PM |
| Lifeguard flights: How to file a flight plan? | Peter R. | Piloting | 14 | April 8th 04 06:40 AM |
| Where is Pilot log file in FS2004? | [email protected] | Simulators | 2 | December 2nd 03 12:56 AM |
| gpligc map file | Mike Stramba | Soaring | 0 | October 3rd 03 09:20 PM |
