Hard landing in a retractable
Old May 17th 05, 06:32 AM
BTIZ
check the brace on the nose gear down locks.. check for new cracks in the
paint.. especially around the down locks..
check the main gear attach points up in the wing/wheel wells.. rivets will
show stress as the gear leg pushed up into the wing..
I've seen on fixed gear 180s.. a pimple in the top metal of the wing where
the gear strut pushed up from inside against it and found the rivets or
bolts sheared
BT
"Frode Berg" wrote in message
Hi!
I had a rather embarrassing hard landing yesterday in a cross wind.
Been years since that happened, most touchdowns have beed silk smooth
(sort of) lately, but yesterday, I somehow managed to flare too high,
resulting in a hard landing, as I also failed to apply corrective throttle
to arrest the inevitable sink rate....
So, the plane settled with a loud squeak on the mains, and came rather
quickly down on the nosewheel....
A slight bounce also occured....not a pretty landing obviously...
Anyway, I am writing this to ask if theres anything in particular that I
should look for as warnings that something might have been damaged with
the landing gear.
The plan is a '68 Arrow, and as far as I could see it looked fine parked.
I notice the nosewheel strut was a bit lower than normal (probably from
the abrupt lowering on touchdown) but I lifted it up manually, and it
stayed the way it normally is.
So, what should I check for in the main and nose landing gear after a non
greaser like this?
Thanks, and pleas no "you should have done this or that" as I already know
most of what I did wrong...:-)
Blushing regards,
Frode
Ejection -v- Forced Landing Cockpit Colin Naval Aviation 27 April 3rd 05 12:47 AM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 06:40 PM
Here is Some video Of Landing In My 150 7676U NW_PILOT Owning 17 July 9th 04 05:10 AM
Highest-Ranking Black Air Force General Credits Success to Hard Work Otis Willie Military Aviation 0 February 11th 04 12:06 AM
VW-1 C-121J landing with unlocked nose wheel Mel Davidow LT USNR Ret Military Aviation 1 January 19th 04 06:22 AM
