"Peter R." wrote in message oups.com... First, a rather basic question: Why is it that all of the moisture that appears in a composite reflectivity map is not all falling? Is this due to the strength of the updrafts within the cell? It seems to me that moisture that appears that heavy on radar would be heavy enough to all fall out of the cloud. Yes, the fact that the water is suspended high in the storm indicates that there are strong updrafts. In a sense, the amount of water that can be suspended aloft is a measure of the "strength" of the storm. It takes a lot of energy to lift and suspend thousands (millions?) of tons of water miles into the air. Once the water is dumped the storm is pretty much over. I have flown through nasty looking CBs that showed only scattered green on radar and there was little or no turbulence. It is diffucult to trust your radar in such cases! Secondly, when ATC reports specific levels of precipitation, am I to assume that they are giving us base reflectivity? What about when FSS gives us precipitation levels en route? Base reflectivity only? Should we be specifically asking for composite reflectivity? I don't know what they use or even if it is consistant. I think that they use the scale where a level three is a thunderstorm, four is a strong thunderstorm and five and six are considered extreme. Mike MU-2 |
| Defining Composites (long) | B Lacovara | Soaring | 1 | September 13th 03 09:04 PM |
| Base Closure List- 2005 | Phineas Pinkham | Military Aviation | 1 | September 10th 03 12:06 AM |
