Actually, yes they did, at least once. My father, a fighter pilot with
no little experience and then assigned to ComFAirWest after action at Coral Sea, Midway, and in the Solomons, was the pilot involved with testing the JATO equipped F4U-1D, Bu No 56048. This just another idea tested to speed up launches. Prior to the F4U test it was also tested using an F4F-3 in l943, but as far as I know only in land based take offs, not launching from carriers. The JATO units for those tests was primitive, but did provide enough uumph to push the Wildcat to a shorter take off run. (Not sure who was the pilot who did the F4F tests.) F4U testing occurred aboard USS Altamaha on 1 March 1944. He made two JATO assisted launches that day. According to him, as far as he could tell, on a straight deck run, the JATO packs added little to the process. The concept was investigated a means to increase the number of planes on escort carriers thru shortening the deck space needed for launch by increasing take off speed. The thrust developed by an R2800 at full power (compared to the Wildcat's R1830) was not particularly enhanced by the JATO units during takeoff. The place where the difference in power had its effect was after the airplane had already left the ship. It was also discovered that, when mixed with salt spray, the exhaust from the JATO units covered everything with an ugly white glop that was hard to remove, especially from the windscreens and canopies of the aircraft parked on the stern. There was some suspicion that this glop might also have some corrosive effect on aircraft and equipment if not removed immediately. Bottom line was that it was an interesting idea, but not terribly practical; in the end, catapults already in use seemed a much better idea. JATO units on F4U's, nor any other USN WWII fighters, were not implemented in the Fleet during the war. Regards, Rich |
| Thread Tools | |
| Display Modes | |
| Corsairs over Ct, | James Lloyd | Home Built | 2 | April 26th 05 11:44 PM |
| Corsairs over Ct. | James Lloyd | Home Built | 1 | April 25th 05 03:06 PM |
| Canadian FAA Corsairs - August 1945 | William Burns | Military Aviation | 2 | June 2nd 04 06:56 PM |
| Canadian FAA Corsairs - August 1945 | William Burns | Naval Aviation | 2 | June 2nd 04 06:56 PM |
| Navalized P-38 Lightning? | Steven Wagner | Military Aviation | 51 | February 28th 04 11:18 PM |
