Practice stalls on your own?
Old May 25th 05, 04:43 PM
Actually, as a CFI I think it is unsafe to *not* practice stalls on
your own. If you understand what is happening during a stall, and have
been taught by an instructor who wasn't afraid of them (some are), then
there is absolutely nothing dangerous about doing them.
I've flown with private pilots who clearly have not practiced basic
maneuvers since their last BFR, if then. They are scared of stalls,
'slow flight' to them is 1.8 Vs0, a 'steep turn' is 20 degrees of bank.
To maintain my personal proficiency, I try to go up by myself at least
once a month, and just do 90 minutes of 'basics'. I advise my students
and BFR rides to do the same. Slow flight in particular is very useful
in increasing your 'feel' for the airplane. Go up, do some approach and
departure (power-off and power-on respectively) stalls. Do some steep
turns, and don't let yourself off the hook until everything you do is
at *least* PTS standard.
The only reason people avoid practicing stalls is because they fear
them. If you are properly trained, and perform them at a 'safe'
altitude above the ground, there is *nothing* to be fearful of. If you
fear stalls, then you need to have some work with a CFI whjo doesn't,
and who understands them and can teach them to you. You can see how
scaed many people are of stalls by watching your local pilots land; I
can't tell you how many pilots I see add an extra 10 knots down the
pipe 'just to be safe'. Works fine with a 172 on 5000 foot runway; but
it really isn't good airmanship.
Practicing the basics (including stalls) is a very good way to improve
one's skills. I can't advise strongly enough that it is a *very* good
idea to devote some time every month (depending on how often you fly)
to just going out and doing the stuff you did in your first 10 lessons
as a student.
Cheers,
Chris
Old May 25th 05, 05:53 PM
Chris Schmelzer
In article . com,
as a student.
Well said,
When I first started practicing stalls and slow flight on my own I was
scared! I had very good aircraft control, even at that point, but the
fear of a spin was always in the back of my head...
But guess what, I was trained well and every one looked good. Just like
my first long cross country was scary because suddenly I had to figure
flight following frequencies, communicate, navigate, enter the pattern
at an unfamiliar airport all on my own, but man did I learn a lot about
where I wasn't truly proficient and fixed those problems quick!
A little fear is good! It keeps you alert and non-complacent! I think
we should all be a little scared on every takeoff and approach to land
as well-it is a high risk part of the flight and that extra awareness
gives you an edge!
Chris Schmelzer, MD
Capt, 110th Fighter Michigan ANG
University of Michigan Hospitals
Ann Arbor, MI
Old May 25th 05, 08:28 PM
George Patterson
jsmith wrote:
From a pilot: Why would you not practice stalls unless you are afraid
of them?
(If you are afraid of them, all the more reason to practice them.)
If you don't practice them and are afraid of them, how will you react
when you get into one "unexpectedly"?
If you practice them, you will understand how you can get into them and
respond appropriately in a timely manner.
And at that point, I know how one gets into a stall, I can avoid the stall, and
I don't need to practice them anymore.
George Patterson
"Naked" means you ain't got no clothes on; "nekkid" means you ain't got
no clothes on - and are up to somethin'.
Old May 25th 05, 09:01 PM
Michael
Good Landings are a result of expertise in slow flight and knowing
exactly where the stall begins...You pretty much need to have a good
feel for stalls to be proficient at short field landing and routing
full stall landings.
There is very good reason that demonstration of approach and departure
stalls are part of the BFR. They are critical maneuvers which are
intimately connected to the two most "dangerous" times in flying.
Yes, I do stalls all the time. Usually alone in the plane and never
below 3000 feet. I also learned to do them under the hood and I would
recommend that any IFR pilot get appropriate training in that maneuver.
Old May 25th 05, 11:29 PM
Blueskies
"Dave Stadt" wrote in message . ..
Ron: No fear of stalls here, I have done them myself and have even
taken a few hours of acrobatics including loops, rolls and spins.
I was just curious what the general outlook on doing them on purpose
was from the general pilot community and from the flight instructors on
here.
Flight without an occasional stall or six, sucks. I have done them with
abandon starting soon as my instructor years ago gave me the go ahead.
Slow flight right on the edge, maybe falling off every once and a while, is the best practice. Do it in the wind, do it
when it's rough, do it at night. Know it....
  #28
Old May 26th 05, 12:08 AM
Michael
Many years ago, long before I ever thought about being a flight
instructor, I met a commercial instrument rated pilot who flew for CAP
and would not do stalls without an instructor. I thought this was
ridiculous then. I still think it's ridiculous. Sstalls performed
properly in an appropriate aiplane should present negligible additional
risk for the proficient pilot. However, proficiency isn't what it used
to be and I am beginning to see a risk to solo stalls that wasn't there
before.
Even a perfectly flown stall has the potential for spin entry (wing
drop) if exactly the wrong gust is encountered at exactly the wrong
time, and most of us can't fly a perfect stall every time - we are all
human and make mistakes. For a proficient pilot, a spin entry is not a
big deal in most airplanes. After all, it is only the entry, and most
normal category light airplanes easily recover from the entry. It's
only once the spin starts to wind up that it becomes an issue. Of
course there are airplanes where that's not true - but most of us are
not likely to fly one.
The issue is - will you recognize the spin entry for what it is and
react appropriately? If you have been trained in full stalls, spin
entries, spins, and spin recoveries, the answer is probably yes - but
these days, many people have not been.
In the glider world, it's different. Most privately owned gliders (and
even many of the rentals!) are single seat. It's not unusual to send a
student with less than 20 hours total time off in a single seater to
check himself out. Since you have to make the first landing count,
doing some stalls to 'feel out' the handling of the glider is not
optional. Because of this, spin recovery training for glider pilots is
essentially universal. No, the FAA doesn't require it - but glider
instructors tend to be rugged individualists who feel that they know
better than the FAA what is necessary - and they tend ot be right.
In the light airplane world, things are not so good. While the FAA
mandates spin training for airplane CFI's, spins are not generally
tested on the CFI ride. As a result, the training is often cursory -
as little as three spins of one turn or less each. That's barely
enough to start feeling comfortable with the recovery, and nowhere near
enough to teach. On top of that, many of today's popular trainers
can't be spun. Spin training for the private pilot is no longer the
rule but the exception. So we have lots of pilot out there whose
knowledge of spin entry and spin recovery is extremely limited.
I'm not going to say that those people should not practice stalls solo
- everyone has a right to choose his own level of risk. I will say
that I sure wouldn't go up in an airplane with one who did, unless I
had my own set of controls. I would also not permit solo stalls for a
student who hadn't spun. When students practice stalls they somewhat
routinely botch them, and that means they're putting themselves at risk
of a spin with enough altitude to recover. I consider a spin a presolo
maneuver and a prerequisite for solo stalls.
As for myself, I don't practice stalls - but when checking myself out
in a new airplane, I do prefer to stall it before I land it.
Michael
  #29
Old May 27th 05, 12:32 AM
Dudley Henriques
Ok, so say you are post-solo and approved to perform stalls OR you are
a private pilot.
Is it smart to go out and practice stalls on a normal basis? For
proficiency and for fun?
Or are stalls something you should only being doing for training?
I would like to hear from both pilots and instructors on your thinking
of this topic.
Also what percentage of you out there do practice them on your own?
Thanks
You can consider yourself safe to perform solo stalls if you have had proper
training in stalls not only entered from normally anticipated flight
attitudes but also from abnormal entries such as accelerated and crossed
controlled entries.
Competent instructors will make sure you have had this training. EXTREMELY
competent instructors will exceed the book requirement in stall training and
make sure you have had basic spin entry and recovery as well.
With this training in your tool kit, you should be perfectly safe in
practicing stalls solo.
Dudley Henriques
  #30
Old May 27th 05, 09:00 PM
PilotCFI
"Dudley Henriques" dhenriques@noware .net wrote in
ink.net:
are a private pilot.
thinking of this topic.
Thanks
proper training in stalls not only entered from normally anticipated
flight attitudes but also from abnormal entries such as accelerated
and crossed controlled entries.
EXTREMELY competent instructors will exceed the book requirement in
stall training and make sure you have had basic spin entry and
recovery as well. With this training in your tool kit, you should be
perfectly safe in practicing stalls solo.
Dudley Henriques
I agree Dudley. My students get this kind of training. I would only
add that to stay safe, keep practicing and get at least an annual eval.
I know every two years is the requirement, but remember the requirments
are minimum standards.
Pilot/CFI/CFII
Navy planes wrap up night landing practice at Iwo Jima, Atsugi Otis Willie Naval Aviation 0 January 25th 05 11:10 PM
Newbie Qs on stalls and spins Ramapriya Piloting 72 November 23rd 04 05:05 AM
Finally, some real solo IFR practice! Guy Elden Jr. Piloting 0 April 15th 04 04:55 AM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 02:27 PM
