Philippe wrote:
Michael Horowitz wrote: My A-65 had the lower half redone. At operating temp. and at idle, the oil pressure is certainly below 15PSI and may be below 10. I asked the company that did the work and they replied "we don't worry about low pressure at idle". Continental says a minimum of 10PSI. I'll get my A&P to put a real pressure gauge on to see what the pressure is. In your experience, does idle typically produce less than 15PSI or am I looking at a problem? spring oil pressure relief valve P/N 21352 Just install a new spring and you get higher oil press. I do that and my pressure jump to the high side of the normal range. It cost me 2 euros (2.6$) for this paperless new spring. The new spring was 1" longer than the 40 year old one. If it don't work, you may suspect your engine bearings are in poor condition. By Philippe - doesnt that relief valve control the upper limit i.e. opens at pressures greater than 35psi? - Mike |
| Thread Tools | |
| Display Modes | |
| 182RG question | Paul Anton | Owning | 11 | May 16th 05 10:45 PM |
| Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 02:11 AM |
| molding plexiglas websites? | [email protected] | Owning | 44 | February 17th 05 10:33 PM |
