A-65 mechanic question
Old May 27th 05, 10:31 AM
Michael Horowitz
Bertie the Bunyip wrote:
Philippe
spring oil pressure relief valve P/N 21352
Philippe - doesnt that relief valve control the upper limit i.e.
opens at pressures greater than 35psi? - Mike
I agree but with a very weak spring, it work for me... Why not try
this first? ....
If you have a weak spring, your higher power settign OP will also be
low.
Yes, it was...
oops, sorry, he didn't say it was normal, but he didn't say it wasn't...
Bertie
Bertie - my upper OP is within the limits of 10-35PSI.
It's my OP at idle that concerns me.
Specifications for the A-65 show an acceptable range of between 10-35
and I'm concerned I may be below that range at idle ( at operating
temp).- Mike
Do we all agree that a pressure relief spring probably will not figure
into the fix for the problem of raising my OP at idle? - Mike
Old May 27th 05, 11:26 AM
Bertie the Bunyip
Michael Horowitz
Philippe
this first? ....
low.
Yes, it was...
Bertie
your pressure above idle should be 30-40. If it's below 30 you don't have
enough pressure. 10 is the lower limit for idle only.
temp).- Mike
might do if your pressure above about 1,000 rpm is less than 30 once your
oil is warm!
Bertie
Old May 27th 05, 05:39 PM
As the engine ages the pump wears and pump clearances open up so that
it pumps less volume. The bearing clearances also increase so oil
flows through them easier. The result is a drop in oil pressure.
I've seen that in my A-65 and others. The original potser had had
his bottom end redone, so unless the mechanic paid no attention to
crank wear and put things together with big clearances, I'd say that
the accessory cover needs to come off and the pump fixed. The most
likely wear is the aluminum pump cavity, since it sucks unfiltered oil
and is easily scored up. If it's a homebuilt the cover plate could be
lapped and the pump housing face machined lightly to reduce the
endplay. If there's serious scoring the whole accessory cover needs
replacing. And where do we find a new A-65 cover these days?
Dan
Old May 27th 05, 07:00 PM
Bertie the Bunyip
Michael Horowitz
Philippe
this first? ....
low.
Yes, it was...
Bertie
temp).- Mike
Um, no, the range for the A-65 is 10 minimum for idle, but it's 30-40 for
higher settings. If you've got less than 30 when your oil is hot,
youhaven't got enough, unless you've got an a-65 I've never seen! My old A-
50 was the same, BTW What's the source of info for your figure of 10-35?
Bertie
Old May 28th 05, 12:22 AM
Michael Horowitz
Bertie
http://www.mooneymite.com/articles/continental.htm
and elsewhere - Mike
Old May 28th 05, 10:32 AM
Bertie the Bunyip
Michael Horowitz
for higher settings. If you've got less than 30 when your oil is hot,
old A- 50 was the same, BTW What's the source of info for your figure
of 10-35?
Bertie
Note that it says 30-35 for cruising. I have a Continental manual in my lap
and it specifies 30-40 for cruise. 30 is fine though towards 40 is better,
but if you have less than that at anything above about 1500 revs and you're
not running sewing machine oil, you don't have enough to keep from scraping
bits of metal together on your cam or your bottom end.
Bertie
Old May 28th 05, 12:34 PM
Michael Horowitz
Michael Horowitz
m:
Bertie
Bertie - I think I'm fine at the high end. My only concern is the
minimal OP at idle. - Mike
Old May 28th 05, 07:50 PM
Bertie the Bunyip
Michael Horowitz
Michael Horowitz
om:
my lap and it specifies 30-40 for cruise. 30 is fine though towards 40
is better, but if you have less than that at anything above about 1500
revs and you're not running sewing machine oil, you don't have enough
to keep from scraping bits of metal together on your cam or your
bottom end.
Bertie
OK, well if your pressure is good at the high end, it's probably not the
relief valve. Any adjustment or replacement I've ever seen on that usually
changed it right across the board. In fact, if it's OK at the high side and
you replace it or put some washers in or whatever, you'll probably find it
going over the top on the high side and staying there. OTOH, it costs
nothing but a bit of time to try it.
Bertie
182RG question Paul Anton Owning 11 May 16th 05 10:45 PM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 02:11 AM
molding plexiglas websites? [email protected] Owning 44 February 17th 05 10:33 PM
