Resorcinol is the recommended adhesive for wooden aircraft?
To what degree is carpenters glue the same thing? |
wrote in message oups.com... Resorcinol is the recommended adhesive for wooden aircraft? To what degree is carpenters glue the same thing? Others are more experienced, but I read that carpenters glue is to never be used on aircraft. I think the problem is that it dries too brittle. -- Jim in NC |
On 11 Jun 2005 17:58:50 -0700, "
wrote: Resorcinol is the recommended adhesive for wooden aircraft? To what degree is carpenters glue the same thing? To about the same extent that staples are rivets. Ron Wanttaja |
From what I hear carpenters glue does not go well with moisture, and weakens
under humid conditions. I have found that T-88 makes one heck of a bond, it's a two part epoxy. How well it holds up after years of flying, I don't know yet ..have not gotten there yet But there are several Volksplanesflying that have been made with it and are doing great. As Mr Morgans pointed out..brittleness. It seems from what I have read on that subject it really plays a role in any kind of a gap between parts. The glue just shears right at the joint. I am a pretty good woodworker , but I don't know if every single joint would be as perfect as needed in order to offset the brittle shear effect. Wouldn't advise anyone else try it either. Patrick student SPL aircraft structural mech |
The difference is life and death!
The biggest problem that I see with this discussion group is the smart
ass answers that are given to people with good questions. Listen to Dixon, I've been a carpenter for 25 years and although I will glue just about anything with carpenters glue, I would never expect it to sustain life. Lou |
"W P Dixon" wrote in message ... From what I hear carpenters glue does not go well with moisture, and weakens under humid conditions. I have found that T-88 makes one heck of a bond, it's a two part epoxy. How well it holds up after years of flying, I don't know yet ..have not gotten there yet But there are several Volksplanes flying that have been made with it and are doinggreat. As Mr Morgans pointed out..brittleness. It seems from what I have read on that subject it really plays a role in any kind of a gap between parts. The glue just shears right at the joint. I am a pretty good woodworker , but I don't know if every single joint would be as perfect as needed in order to offset the brittle shear effect. Wouldn't advise anyone else try it either. Patrick student SPL aircraft structural mech I just read the other day that T-88, being an epoxy adhesive, will soften with heat. The recommendation was to be sure the final paint job was mostly white to keep the temperatures inside the structure below 140° F.... |
"The biggest problem that I see with this discussion group is the smart ass
answers that are given to people with good questions." A number of aircraft have failed due to improper glue, causing death to the pilot. Considering using carpenter's glue for an aircraft structure indicates such a lack of basic understanding that I question whether the constructor should be building an aircraft at all. And, with such a lack of understanding of basic materials the questioner should not be reliant on the question is answered. What if 10 people responded and said carpenters glue is fine? What if no one responded. The first few responses were not blunt, nor did they convey the message that to use carpenter's glue was akin to Icarius making his wings out of wax. I always appreciated when my teachers were blunt about a stupid question. The fact was that the question indicated the questioner was considering sustaining life with carpenter's glue. Colin |
I suppose I should have been more politically correct and made a response
such as: Although it is possible to use carpenter glue for aircraft, it is not recommended. The odds of the wings falling off during flight increase, and if the wings fall off during flight, the prospect of death increases. It is also possible to use a glue made from flour and water, but that is not recommended for the same reason. If you use a glue such as resorcinol, you will have the confidence that the wings are less likely to disassemble while in flight. It is recommended that you follow the plans of the aircraft designer and not make the spars out of lumber purchased at the local lumber discount store. Have a nice day. |
On Sun, 12 Jun 2005 13:26:49 GMT, "COLIN LAMB"
wrote: "The biggest problem that I see with this discussion group is the smart ass answers that are given to people with good questions." A number of aircraft have failed due to improper glue, causing death to the pilot. Considering using carpenter's glue for an aircraft structure indicates such a lack of basic understanding that I question whether the constructor should be building an aircraft at all. And, with such a lack of understanding of basic materials the questioner should not be reliant on the question is answered. What if 10 people responded and said carpenters glue is fine? What if no one responded. The first few responses were not blunt, nor did they convey the message that to use carpenter's glue was akin to Icarius making his wings out of wax. I always appreciated when my teachers were blunt about a stupid question. The fact was that the question indicated the questioner was considering sustaining life with carpenter's glue. Colin I've got an all-wood plane, that was built with the Hughes FPL 19 epoxy glue, ivented at the Forest Products Labratory. It was probably one of the first Epoxy glues used by the homebuilt crowd. Before, glues like Weldwood were the standard. My plane also has some T-88 used in a few places. The answer is to read some of the great books available from the EAA on wood construction and glues, before ever starting construction on a wooden plane. And if building with plans, you can't go wrong with building with whatever the designer recommends, if that glue is still available. Some glues, like Aerolite, I hear are dissappearing. |
| Thread Tools | |
| Display Modes | |
| KA6E and Foka 4 comparable metal ships - Laister Nugget LP15 | Matthieu | Soaring | 18 | June 7th 05 02:20 AM |
| Removable glue | Lou | Home Built | 2 | April 14th 05 07:57 AM |
| Glue question | [email protected] | Owning | 1 | December 6th 04 04:25 PM |
| Spar gluing | Lou Parker | Home Built | 26 | November 21st 03 09:29 PM |
| Drywall Gussets | Veeduber | Home Built | 5 | October 27th 03 10:03 PM |
