Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Restoration
Towplane strut problem
Old June 14th 05, 09:01 PM
machineman
I am not sure if this is something you want to play around with
yourself. I would consult a licensed aircraft mechanic. There may be a
repair scheme for this or it may have to be replaced. A mechanic
familiar with the aircraft would know. Having worked on aircraft
engines, nothing gets fixed without an engineer working out an approved
repair. Or as we used to say " no engine flys till the paperwork weighs
as much as the engine" :-)
John Sp wrote:
Our gliding club towplane (Piper Super Cub) has developed play in the
Fuselage / Main strut connection - Portside. The bolt and clevis (Fork)
seem to be OK bolt is a reasonably snug fit in the fork. - I presume the
play is in the hole in the Bracket welded to the fuselage. Play seems to
be about 10 thou (+-.25mm) which translates to about .75 inch of "Waggle
" At the wing tip. Can anyone help with the following -
What is the permitted wear at this point ? (If any)
What approved repair methods can be used here?
Thanks in advance
Best wishes from Cape Town
John Spargo
Heater problem fixed! Jim Burns Owning 14 December 17th 04 11:38 PM
SSA Website problem Raphael Warshaw Soaring 2 February 12th 04 03:56 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Home Built 78 December 3rd 03 10:10 PM
Help with serious Glider Registration Problem Soaring 5 November 12th 03 05:01 PM
Problem: Ground Speed Estimate with Volkslogger and WinPilot RamyYanetz Soaring 3 August 26th 03 04:06 PM
